st165 swap to gen 7 AWD 3SGTE 750hp
Re: st165 swap to gen 7 AWD 3SGTE 750hp
Postby outinnowhere3193 » Mon Apr 24, 2017 12:34 am
Actually had 2 days to work on the car. So I made a little progress. I cut the trunk out and plated it in. Added a sway bar to the car from a MR2 and started to add the gas tank. For now I'll live with it but I will probably redo it. It isn't the lowest point of the car but it does stick down about 4 inches past the back bumper. But with the car being black and the gas tank being black it isn't horrible.
outinnowhere3193
Images: 5
Postby sMARTINside » Mon Apr 24, 2017 11:37 am
Don't worry about the fuel tank sticking out 4 inches down... it's about the same on the Alltrac! 8)
sMARTINside
Postby 8BitBrody » Mon Oct 23, 2017 5:01 am
Please tell me you're still working on this. I'd love to see an update.
8BitBrody
Postby outinnowhere3193 » Mon Oct 23, 2017 9:25 am
I've been swamped n haven't touched it. But I promise it's still gonna happen!
outinnowhere3193
Images: 5
Postby UtahSleeper » Wed Nov 08, 2017 3:35 am
Looking forward to seeing this. Progress seems to be going decently.
UtahSleeper
Postby outinnowhere3193 » Sun Jan 07, 2018 1:25 pm
So I've been very busy and finally getting around to working on the car. So far I've ran into some small issues.
The goal was to use the 1988 shifter and cables. They are to short and when I look up the oem shifter and cables they'll set you back about 300 dollars and Idk if they will directly work. So I'm going to have to redo the bracket1s and I'll extend the shifter cable and make it work.
I did however successfully add in the clutch and reservoir from the 88. I had to cut the clutch and re angle it do to it hitting the floor before full range of motion.
Lastly the last big problem I have is the steering. It's in the way of my driveshaft. So I gotta look at it and see if I can move the 88 steering rack into the car.
Otherwise as of right now the car has the driveshaft installed from the diff forward. The engine still has to come back out because I have to make a motor mount (passenger side) and alter that the steering so I can do my driveshaft.
After that I will reinstall the engine.
Oh I'm also needing a side feed intake. Will probably be several weeks before I get my intake and transmission parts.
https://drive.google.com/folderview?id= ... 3tYBkOCHNC
outinnowhere3193
Images: 5
Postby 8BitBrody » Sun Jan 07, 2018 11:37 pm
I have always hated the 7th generation Celica, but I feel like you are making it a car worth driving. I'd love to give this thing a spin when you have it done, haha. Be sure to take some videos for us.
8BitBrody
