HOYS' ST185 Res-Q
HOYS' ST185 Res-Q
Postby hoys » Tue Aug 22, 2017 12:51 pm
Making a thread for this car as there was a good bit of interest in following it.
Vehicle picked up from member gab on 8/21/2017 and trailered to TGA Performance in Colorado Springs, CO. I live in SW Ohio. One way flight booked to CO this Friday 8/25/2017 to meet up with the car and get it road worthy again.
Some pictures from gab and initial pickup:
To-do list:
* Battery
* Tires
* Fuel pump and drain gas tank
* Replace all fluids
* Inspect all wearable parts
* Clean rodents
* Drive back to Ohio
hoys
Re: HOYS' ST185 Res-Q
Postby underscore » Tue Aug 22, 2017 8:30 pm
* rinse it off
That interior looks amazing, and the rest of it looks unmolested. Definitely keep us posted on how things go with it.
Postby Tecker185 » Tue Aug 22, 2017 9:15 pm
Is it a 92? Im jealous love that color
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby FC Zach » Wed Aug 23, 2017 4:37 am
underscore wrote:* rinse it off
LOL
and it still has the ABS actuator cover!
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby underscore » Wed Aug 23, 2017 5:52 pm
FC Zach wrote:and it still has the ABS actuator cover!
I didn't even know they came with covers :lol:
Postby puppet623 » Thu Aug 24, 2017 1:40 am
wow your lucky to find such a stock car. My parts car was a perfect stock st165 but it got wrecked.
Instagram: Oddball_8
1988 Celica Alltrac
2004 Mazda Rx8
1990 4X4 Dodge Dakota
puppet623
Postby FC Zach » Thu Aug 24, 2017 2:57 am
It's the little things in life :)
With that said. . if you ever feel like parting with anything, I'd love to have that :|
FC Zach
Images: 9
Postby hoys » Sat Aug 26, 2017 5:31 am
Finally saw the car in person today. The car is in even better shape in person.
Took the intercooler off, pulled the plugs, scoped the bores, looked at the turbo. Everything looks decent. Car has wheels locks so I have to figure that out. No keys in sight.
Tomorrow trying to get the car to turn over and run. Most likely will have to replace the fuel pump before it runs.
hoys
Postby hoys » Mon Aug 28, 2017 1:43 am
Got the car up and running! All we needed to do was drop the gas tank, drain the old gasoline, and put a new fuel pump in as the unit in the car wasn't responding. Once out of the car and connected directly to a fresh 12v source, the old pump jumped back to life. We put the new unit in for good measure.
After running the old gas out of the system we idled the car for 30 minutes. The coolant system held pressure and the coolant fans worked, the A/C still blew cold and all the lights worked. Who knows how to reset the SEC (urity?) error on the radio?
Either the timing idler or tensioner made noise when the engine speed was around 1,500 RPM. Not inspiring for me to drive the car 1,100 miles home. Ended up getting plane tickets back to Ohio and contacting a transporter to bring the car here to finish the rehabilitation of the vehicle. Timing set, new tires, new fluids, we will be good to go!
Here are some pictures of it cleaned up:
hoys
Postby FC Zach » Mon Aug 28, 2017 1:46 am
Looking good!
FC Zach
Images: 9
Postby f3ared » Mon Aug 28, 2017 5:00 am
Man that looks clean under all that dust!
Am I seeing things or did the US model ST185s have a different bumper to the rest of the world?
f3ared
Postby jwgt41 » Mon Aug 28, 2017 11:49 am
Beautiful grab! How many miles on it?
1990 Toyota Celica All-Trac
2001 Toyota Solara
2003 Subaru WRX
2005 Toyota Tundra
2011 BMW 335iX
jwgt41
Postby hoys » Mon Sep 04, 2017 3:16 am
Car arrived via the transporter to Ohio last night. All is well.
hoys
Postby hoys » Sun Sep 17, 2017 11:59 pm
Update!
I haven't had much time to work on the car, but I've been doing small things.
Put my 7th gen wheels on. Its nearly impossible to find the proper size tire for 15"s any more. These wheels fit the look but not the right offset in the rear. They will work for now.
(full rez: https://i.imgur.com/4EfXJbE.jpg)
Gave the car an even better bath and clay bar. I'm trying different waxes and sealants to see what the paint likes. The car will surely need a good buff as there are a few scratches here and there.
Bled the brakes, car stops well.
I bought all of the timing components and will be changing all of those over next week. Can't wait to drive this going into fall!
hoys
Postby lalojamesliz1 » Mon Sep 18, 2017 12:17 am
Wow! Looks great :smokes:
91 Celica all-trac gen3 swap
87 toy 5speed long bed
69 mustang
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
