Switch to full style
Get off the pavement!
Post a reply
Re: st185cs rally car
Tue Mar 30, 2010 8:48 pm
Thanks for the heads up Insanity, i completely missed the update with brake install :smokes:
Sun Sep 19, 2010 3:03 pm
This is going to be a killer rally car.
Just a heads up about the brake line holder bolt on the inside of the rear DMS shocks- I am not sure about on a 185 but on my 165 this bolt rubbed against the wheel well and almost disabled my rear brakes during a rally.The fix was to switch to a rounded off lower profile allen head fastener. I think that my problems could have been exaggerated by weak rear cradle mounts allowing the rear to shift excessively when loaded but it is still something to watch out for.
Best of Luck with the build!
Re:
Wed Oct 06, 2010 10:07 pm
tybrinturbo wrote:my new brake kit
[http://s271.photobucket.com/albums/jj151/tybrin/?action=edit&current=DSCN2128.jpg]
toyota sienne rotor and alcon caliper, the braket is buit by dms in montreal[/img]
As far as I remember Sienna have 5x114.3 stud pattern and Alltracs have 5x100.
Did You bored stud holes on the Sienna rotors to change the PCD?
What is disc diameter? I see that it fits in 15 inch rim with no problem.
Wed Jul 27, 2011 7:22 pm
update
new head 3e gen
Wed Jul 27, 2011 11:13 pm
Lookin good man!
Re: Re:
Thu Jul 28, 2011 11:05 am
no problem for 15 inch rim, i drill new holes, i have the same setup for the back
Tue Aug 02, 2011 8:04 pm
inside
Sun Aug 21, 2011 3:00 am
I fucking love this car. :D
Please keep posting.. I want moar!
Fri Aug 26, 2011 7:06 am
What's the spec on the DMS Gravel springs ? Rating (hard coil part and soft coil part ) and Length ?
Thu Oct 13, 2011 9:36 pm
What are you planning for windows? I see you removed door bars. That is illegal in US. Hope its allowed in Canada. BTW we calculated that converting to manual window cranks saves no weight. I am going back to electric. I however am planning plastic rear hatch and door windows. They are made in UK now and used on several Mitsu and Subi cars here in US. They have a set for ST185. No door frames needed. Very inexpencive. Good luck with DMS. If you are beginner they will last for a while. If you are fast they may not survive even one event. Also you will need rear wheel scraipers for rear or kiss your rear calipers good buy. I also hope you have resourses for urethane. You will need horizontal skirts from the back edge of the floor to rear control arms.
I see you didn't do front end caster correction. It helps alot.
What are you using for rear brakes. Idealy should be same as front but with smaller piston diameter.
There is a dog transmission and quick steering rack made for this car. Quickner also works but requires electric power steering pump.
Ask me how I know all that...........
Nice welding.
Fri Oct 14, 2011 11:11 am
http://www.plastics4performance.com/default.asp?
Check it out. Nice windows.
Fri Oct 14, 2011 1:11 pm
http://www.flex-a-lite.com/auto/html/mojave-heater.html
We and many in UK use this for a heater. Very compact.
Sun Oct 30, 2011 12:49 am
This is awesome.
+2 we use plastics for performance at work. Nice stuff. :smokes:
st185cs rally car
Sat Jul 07, 2012 10:28 pm
Love the car man! Sick setup.
Thu Jan 03, 2013 3:18 pm
Love that project! :twisted:
Post a reply
