Prepping the 165 for rally but also track work
Get off the pavement!
Postby TRDcelica90 » Fri Apr 16, 2010 8:10 am
hey guys i wanna rally my car but also hillclimb, track work and motorkhanas what kinda all round set up in regards to brakes and suspension should i look at??
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90
Re: Prepping the 165 for rally but also track work
Postby Gary ST165 » Sat Apr 17, 2010 12:25 am
ST165 turbo 4WD
Gary ST165
Postby Corey » Sat Apr 17, 2010 5:56 am
ORRRRRR lol
if you cant afford that, might also consider Ksport which makes some rally suspension and big brake kits of different sizes.
Not in the same league as DMS and AP, but far more affordable option.
Corey
Images: 50
Postby TRDcelica90 » Sat Apr 17, 2010 7:13 am
Thanks gary: something to consider when i get more serious with it.. but low budget atm, thats just over 3x the amount i paid for the car lol..
Thanks cory i will look into it.. was also thinking the konis and whiteline springs. But im gonna have t osee what kinda things ill be racing on, incase there are HUGE bumps and jumps lol
for brakes i was just considering maybe ferodo DS2500s or some EBC. not looking at changing calipers yet..
would love to get this into some serious rally/tarmac events one day and bring back these awesome cars..
thanks
TRDcelica90
Postby Gary ST165 » Sat Apr 17, 2010 9:02 pm
the BC RM series inverted mono tube type coilovers are another budget option. (cheap DMS copy)
http://www.bc-racing.co.uk/rm-series-coilovers.asp
but you do want a coilover for the extra ride height (rally) rather than crappy fast road "lowering" springs and hence very limited shock travel.
whiteline springs are a no no. many UK 165 owners have moved on from these as they are simply no good for track, let alone rally. barely adequate for straight line road use :lol:
ST165 turbo 4WD
Gary ST165
Postby TRDcelica90 » Mon Oct 18, 2010 7:46 am
bringing this back to life because i have more questions..
In terms of cooling, i want to go a nice alloy rad and im thinking ASI?? (budget racer), but will it hold up to the extra strain placed upon it?
electric water pump the go or will standard suffice?
Timing belt?? will a standard toyota timing belt cut it or should i look at aftermarket "extra strength" belts, or are they a load of shite?
thanks guys
TRDcelica90
Postby MWP » Tue Oct 19, 2010 8:59 am
Are you on Toymods? If not, sign up ASAP :)
The answer is "no" to all your questions.
None of that is required unless your pushing the engine way over standard (ie, >200kw/atw).
Return to Rally Row
