Looking for cushion center member mounting 52236-20050
Postby Kyle Hunter » Sat Aug 26, 2017 2:30 pm
Looking for cushion center member mounting 52236-20050. I believe I need three 1 rear and 2 front, not 100% sure that front and rear are the same.
Kyle Hunter
Re: Looking for cushion center member mounting 52236-20050
Postby rrain3288 » Sun Aug 27, 2017 1:57 am
Not sure what your plans are but I know speedsource sells a solid mount kit to replace the old rubber mounts. I use them in my car and haven't had a single complaint.
http://speed-source.net/?wpsc-product=g ... r-bushings
Why me!!!!
92 Celica Alltrac-gen 3 swap
rrain3288
Postby Kyle Hunter » Sun Aug 27, 2017 2:53 pm
rrain3288 wrote:Not sure what your plans are but I know speedsource sells a solid mount kit to replace the old rubber mounts. I use them in my car and haven't had a single complaint.
Thank-you, searches were able to find that but nothing else. It's the way we'll end up going if we can't find something cushioned.
Kyle Hunter
Postby Kyle Hunter » Tue Aug 29, 2017 5:14 pm
Went ahead and ordered from speed-source
Kyle Hunter
Postby Kyle Hunter » Wed Sep 06, 2017 8:35 pm
Anyone know what the deal is with speed-source? Phone number doesn't work, no response to e-mails, CC was charged just fine.
Kyle Hunter
Postby underscore » Wed Sep 06, 2017 10:59 pm
I haven't dealt with speed-source, but I got similar metal replacements from xiiimotorsports (klue on here) that fit very well if you end up having the cancel the order with speed-source.
Postby Kyle Hunter » Thu Sep 07, 2017 1:02 pm
underscore wrote:I haven't dealt with speed-source, but I got similar metal replacements from xiiimotorsports (klue on here) that fit very well if you end up having the cancel the order with speed-source.
Thank-you, I was able to make contact through Facebook and was told that the item shipped yesterday morning. I guess we will give it through the weekend.
Kyle Hunter
Return to Parts Wanted
