[How to] Install ST205 rear brakes
Postby Meurz » Tue Apr 03, 2007 10:01 pm
http://www.turbocelica.nl/howto-st205rearbrakes.htm
Or go to http://www.turbocelica.nl --> Tuning --> How to.. --> How to install ST205 rear brakes
Turbocelica.nl
Meurz
Postby sleeper » Wed Apr 04, 2007 5:43 pm
how about making one for st205 front brakes?
sleeper
Postby Gary » Wed Apr 04, 2007 6:29 pm
The front one is not bolt on.
You will need either to make custom brackets or grind the rotor down (bad idea)
93 ST185
Gary
Postby alexgt4514 » Sun Aug 03, 2008 2:37 am
is there any of the st205 calipers ?
alexgt4514
Re: [How to] Install ST205 rear brakes
Postby quieter » Thu Jan 12, 2012 1:16 pm
hi guys! so yeah i fitted everything in the back from an st205 wrc to my st185 and i just need to fit everything in front now, did anyone ever try it by grinding the rotors or make custom brackets? and yeah i know this is an old post
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby CMS-GT4 » Thu Jan 12, 2012 1:22 pm
Yes people have tired that. Do a quick search and you will find a couple of threads dedicated to different solutions to mounting the 205 calipers.
Postby AFCor » Mon Jan 16, 2012 2:54 am
viewtopic.php?f=44&t=19242&start=150
here's one example of a st205 front install by darthripley. Very well done I might add. It starts about halfway down the page.
'90 All-trac - His
'98 Land Cruiser - Hers
'02 Jetta TDI - DD (50+MPG)
AFCor
Postby aus jd 2703 » Mon Jan 16, 2012 3:11 am
Meurz where do you buy your stuff from? Particularly your gopher radiator and endless rear pads and
Rotors? Thanks
aus jd 2703
Postby bmt » Mon Feb 27, 2012 4:34 am
Are they a bolt on to a St165 as well? What size rim do you need to clear the brakes?
bmt
Postby quieter » Tue Feb 28, 2012 2:08 am
for rear or front?
-Simon
quieter
Postby tubasteve » Tue Feb 28, 2012 2:38 am
bmt wrote:Are they a bolt on to a St165 as well? What size rim do you need to clear the brakes?
Few 16$, closer to 17 though. Well the 205 ran 16s @least
tubasteve
Postby bmt » Tue Feb 28, 2012 3:58 am
quieter wrote:for rear or front?
Oh rear, as I thought St205s are totally different for the front?
bmt
Postby quieter » Tue Feb 28, 2012 4:26 am
rear is bolt on and yeah 16 inch minimum to clear the caliper
-Simon
quieter
Return to How To
