MR2 Bypass valve install, recirculated. A couple questions..
Postby maxaud » Fri May 11, 2007 2:25 am
OK, so I got my samco on and attached my BOV and had it venting to atmsphere and it was extremely loud. I wasn't very fond of the running conditions with it running rich, nor the gas bill so I recirculated it today and can't here a single noise went I shift. Do you guys still think it's working? It feels a more 'peppy' after shifts then it did stock. There is no more purge noise at all so I'm questioning if its working.
some pics... (click to make larger)
Picture of my Turbo, the wheel looks bigger than all the other CT26's that I have had.. anyone else see what I see?
the flange welded onto the elbow for recirculation... not bad for how thin that metal is.
the pipe back attached to the rest of the intake lines.
The Samco hose install'd and put in place..
The gap inside, cell phone picture...
The BOV ---> intake tube...
the whole thing assembled...
Did I miss something?
Should I be hearing the purge still or will the tube muffle it so much that I can't hear it at all?
Should I put it back to stock?
thanks guys.
-Dustin
maxaud
Postby smog7 » Fri May 11, 2007 3:05 am
thats pretty effin cool! Did you do the welds yourself? I need to look into doing something like this, I already have the bpv. Did your mpg really suck that much after venting to the atmosphere??
-omar
rally tarmac 1990 st185
smog7
Postby RedCelicaTRD » Fri May 11, 2007 3:08 am
You wont hear much due to the AFM and the airbox.
Postby maxaud » Fri May 11, 2007 3:47 am
It was so loud when it was vented to atmosphere that I thought I would hear something. No sound at all when I shift. The turbo spool sounds a little different maybe.
I didn't do the welds. I didn't trust myself with how thin the intake metal is.
Every time I shifted I could smell fuel. It may be different on my car seeing as how it is JDM where it has a more aggressive fuel curve. Since going from stock to this my car seems to hesitate a little usually one 1st gear. I might have fowl'd or got my plugs real dirty from venting to atmosphere for a couple weeks.
Wierd thing though, once I completed the install. I forgot to plug back in the AFM and I drove around with it disconnected....
also, the picture of my turbo; does it look different then anyones? To me it seems larger.
-Dustin
maxaud
Postby Gary » Fri May 11, 2007 4:20 am
That looks OK to me. :)
93 ST185
Gary
Postby maxaud » Fri May 11, 2007 4:27 am
Gary, I know yours is vented to atmosphere. Have you had any problems with hesitation? mainly in lower gears.
-Dustin
maxaud
Postby Gary » Fri May 11, 2007 4:33 am
Once in a while when down shifting from 2-1.
It also backfires sometime too.
I learn to live with it and adjust my driving accordingly. :)
93 ST185
Gary
Postby maxaud » Fri May 11, 2007 4:36 am
I never had a backfire but I have a lot of hesitation. Wanna shed some light on my turbo? Does it look to be a stock ct26?
P.S.- isn't it like 2 in the A.M. there?
-Dustin
maxaud
Postby BoostedBlueToyotas » Fri May 11, 2007 8:12 am
You dont hear any noise from the unit on stock MR2's either. Recirculating
= no noise even with an aftermarket intake (or at least I dont hear the BPV on my MR2T and I am using an apexi intake)
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby 88st165 » Fri May 11, 2007 12:18 pm
looking good.... i just finished recirculating my mr2 bpv also but i havent had a chance to drive it yet... when vented it hesitated pretty noticably when i would shift into any gear after boosting so i only drove it vented for a day.... i do admit it did sound cool...
this reminds me of a conversation i had w/ an srt4 owner after we had raced...
srt4: i knew you were turbo'd after i heard you bov, what bov are you running?....
me: oh... none, thats just compressor surge you're hearing hahaha...
srt4: :shock:
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby gpmarzan » Fri May 11, 2007 2:45 pm
that turbo seems to have a bigger wheel. Maybe a 46mm trim? :shrug: It does look bigger than your stock compressor wheel.
Patrick M.
st165
gpmarzan
Postby wizzards581 » Fri May 11, 2007 3:07 pm
GARY: your using a mr2-T bypass valve vented to air? or aftermarket bov.
-03 matrix XR
wizzards581
Postby cardude » Fri May 11, 2007 3:59 pm
88st165 wrote:looking good.... i just finished recirculating my mr2 bpv also but i havent had a chance to drive it yet... when vented it hesitated pretty noticably when i would shift into any gear after boosting so i only drove it vented for a day.... i do admit it did sound cool...
srt4: :shock:
haha that sounds familiar.
88 Alltrac
91 zx600
81 kz1000
87 4runner
cardude
Postby Gary » Fri May 11, 2007 4:01 pm
wizzards581 wrote:GARY: your using a mr2-T bypass valve vented to air? or aftermarket bov.
I'm using MR2 BPV vented to atmosphere.
93 ST185
Gary
Postby maxaud » Fri May 11, 2007 4:11 pm
that's kinda funny that we ran the throttle cable through the same spot. I didn't even realize it until now.
-Dustin
maxaud
Return to How To
