how to upgrade 165 turbo/ic to 2 gen turbo/205ic ** UPDATED*
Postby 88st165 » Thu Nov 16, 2006 4:31 pm
^hmmmm.... interesting as i never would have considered those b/c i was unaware of that problem.
are these what you are talking about? they dont specify turbo but only 2.0L
http://store.summitracing.com/partdetai ... toview=sku
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby saved_1992 » Thu Nov 16, 2006 4:56 pm
yep, i would also check the bearings to make sure they are in good shape, using the ct27 you will be putting alot more strain on these
check with d1alltrac for the pics of the rod that went through the block, if i remember the bolt was missing and the rod was completely broken.
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby 88st165 » Sun Dec 31, 2006 11:45 pm
ok i just checked the bearing and they look great.... my question was is there a special tool to press the rod bearings out and press the arp bolts in or would i have to remove the pistons and take them to a machine shop?
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Sat Aug 18, 2007 5:27 pm
:D 11800 come on sticky this :lol:
mike
omaha,ne
saved_1992
Postby 88st165 » Sat Aug 18, 2007 7:02 pm
i guess its just not popular enough of a mod... :shrug:
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Tue May 06, 2008 7:17 pm
/ :shock:
mike
omaha,ne
saved_1992
Postby 88st165 » Tue May 06, 2008 8:02 pm
haha, my swap is still kickin ass... 16psi on ct27 and water injection is actually pretty decent.
Black st165 - gone
88st165
Images: 2
Postby wakkjobb » Tue Aug 12, 2008 11:58 pm
My quick two cents:
For the metric threaded rod, I got a section of 3/8" plain steel rod from Home Depot and made my own studs. Works good so far...
Dan
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby All-Trac Dude08 » Mon Oct 27, 2008 9:50 pm
88st165 wrote:well i finally finished after gathering all the parts and having a day off to finish up all loose ends.... sorry for so many pics...
thats all i got, sorry for so many pics... i havent had a chance to drive it yet to see how well the twin entry works or made a difference... ill report back when i get a chance.
Thanks to ImageShack for Free Image Hosting
One quick question about the little hose that goes in the turbo next to upper radiator hose. In my car, seems the previous owner blocked that hose and didn't hook it up to the turbo, should I hook it back up? or should I just leave it how it is?
All-Trac Dude08
Postby slappyNuts » Mon Jan 12, 2009 7:21 pm
i will be doing this swap next weekend :-D thank you so much for the write up!!! :D
slappyNuts
Postby 88st165 » Tue Jan 13, 2009 2:09 am
Whoa sorry I havent been keeping up with this post. Im sure you have figured it out by now but ya I would hook up the water lines.
Black st165 - gone
88st165
Images: 2
Postby All-Trac Dude08 » Tue Jan 13, 2009 5:40 am
lol it's ok. When I posted that question I didn't know anything about my car, but after having to replace the turbo, I found out that the previous owner had done the twin-entry swap already, so I'm guessing that hose isn't needed.
1988 ST165 Freshly Rebuilt Engine and Turbo
All-Trac Dude08
Postby 88st165 » Tue Jan 13, 2009 7:22 pm
I run the water lines with my twin entry swap. If you dont push the turbo that hard then you will be fine w/o using them but just remember that the turbo was designed to be water cooled.
Black st165 - gone
88st165
Images: 2
Postby All-Trac Dude08 » Tue Jan 13, 2009 9:59 pm
88st165 wrote:I run the water lines with my twin entry swap. If you dont push the turbo that hard then you will be fine w/o using them but just remember that the turbo was designed to be water cooled.
Well, I'm running the st185 water lines, so those feed my turbo some coolant.
All-Trac Dude08
Postby 88st165 » Wed Jan 14, 2009 12:00 am
Thats even better. You really have to hack up the 165 ones to make them work.
Black st165 - gone
88st165
Images: 2
Return to How To
