how to upgrade 165 turbo/ic to 2 gen turbo/205ic ** UPDATED*
Postby ChrisD » Sun Jan 22, 2006 3:28 pm
FYI: an ST185 throttle body will give you an extra 1/8" to work with.
1988 ST165
1994 ST205 WRC
ChrisD
Postby 91 alltrac » Mon Jan 23, 2006 9:05 pm
just looking at the clearance issue with the acuator arm and its about 2mm
using the 1/2 spacer, the 3/8 might be a little close but would work with a little work.
the stud issue, I was planning on getting longer bolt and making studs but wanted to get the car going. they are grade 8 bolts so I would have to use a cutoff tool at work which I didn't want to wait for. also I took pretty good mesurements and the bolts actually go deeper into the head then the stock studs.
92 alltrac
91 alltrac
88 alltrac
91 alltrac
Postby 88st165 » Wed Feb 01, 2006 8:09 pm
so far i have collected:
-twin entry manifold: $35 from mr2 owner
-twin entry ct26: $100 from same mr2 owner
-flange/spacer: $86 from JGS, waiting for arrival
-aussie dp: $200 from rightrac, waiting for arrival
-gaskets posted by saved_1992: $88 from local toyota dealer
-longer exhaust manifold studs: ?????
total so far:= about $509 just to give people a rough estimate if they also want to do this.
is there anything i am missing? possibly a thinner radiator fan for clearence? any extra hoses, lines, gaskets, etc that people have had to purchase because they ran into a problem?
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby saved_1992 » Wed Feb 01, 2006 8:58 pm
88st165 wrote:so far i have collected:
way to go on getting parts seems like you did very well
should also need a longer hose from the turbo to the ic inlet
studs (long bolts with the heads cut off) and matching nuts/washers
you should be able to trim the fan shroud for needed clearance
is your rubber oil return hose in good shape? warning do not use worm gear hose clamps on this hose they will cut it
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby 88st165 » Thu Feb 02, 2006 5:06 am
im not sure about the return line... i havent really inspected it, what are the sign of a bad one?
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Thu Feb 02, 2006 10:47 am
88st165 wrote:im not sure about the return line... i havent really inspected it, what are the sign of a bad one?
will be leaking/brittle, should be nice and flexible
mike
omaha,ne
saved_1992
Postby 88st165 » Sat Feb 04, 2006 10:15 pm
for those that have already completed this swap/mod, how does it perform? is there a noticable gain with using the stock twin entry turbo? my personal reason for doing this is that i want to run the SB kit in the future and plus i am having prob with my current stock turbo. does it spool better/faster?
Black st165 - gone
88st165
Images: 2
Postby d1alltrac » Sun Feb 05, 2006 1:50 am
i guess it spools a little faster but its not that noticable, i really just did it cause my stock turbo was blown. :wink:
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby 88st165 » Thu Mar 02, 2006 10:53 pm
well i dove into it today and everything came off without a hitch...... now the 2nd gen stuff is a different story, can anyone offer me advise on getting the oil line to bolt up? i cut the support bracket already but it still seems very stubborn and wont budge. this seems to be the worst part about this mod.
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Fri Mar 03, 2006 1:04 am
on the test fit i eye balled where the line needed to be, removed the turbo/manifold assem and bent by hand to get as close as possible to bolting up. when was close used a straight pick to finish the adjustment, personally was not too bad just went slow and made small adjustments as needed.
mike
omaha,ne
saved_1992
Postby 88st165 » Fri Mar 03, 2006 3:53 pm
i have it all lined up but it just wont go farther down, that "s" shaped bend in the line that comes from the oil cooler looks like it is on the verge of being kinked if i force it to go any lower... is there anyway to replace that line with something more flexable? could rubber oil line possibly be a solution?
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Fri Mar 03, 2006 4:33 pm
try pming the guys that have just done this, they might not visit this thread.
you are right about the adjustment, it is on the verge of kinking the line
I dont know about a rubber line, oil will deteriorate it, you could get special oil lines, then you have to worry about how to secure the lines to the metal lines
mike
omaha,ne
saved_1992
Postby 88st165 » Fri Mar 03, 2006 5:36 pm
i know they have oil cooler rubber hose... there isnt that much pressure going through that is there? im thinking of maybe cutting the "s" bend out and flaring the ends then putting the rubber hose to that? :shrug: i dont know, thats basically whats holding me back from completing this, oh and i cannot find bolts long enough to use as the studs in grade 8 and i also cannot find longer studs period. i searched the internet and couldnt find crap.
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Fri Mar 03, 2006 6:03 pm
what size do you need?
have you tried getting a metric threaded rod? they come in 1-3 meters in length and in different metals from stainless steel to grade 4.6
mike
omaha,ne
saved_1992
Postby d1alltrac » Sun Mar 05, 2006 3:33 am
havent checked this thread in a while :doh:
when i bent the line i eyeballed it like mike to start off, after that i put the whole manifold/turbo assembly on to see how far off i was...then i used a screwdriver and stuck it through the screw holes and used it to line them up, being very careful not to kink it of course. it was a huge PITA to get the first bolt in (i used a longer one to make it easier) but once the first bolt was in it was pretty straight forward.
have you checked local hardware stores for the studs? a couple weeks after i did this i was at ACE hardware looking for something and i noticed they had "exhaust manifold studs" in lots of lengths and threads, it pissed me off and i didnt buy any :P
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Return to How To
