how to upgrade 165 turbo/ic to 2 gen turbo/205ic ** UPDATED*
Postby 88st165 » Sun Mar 05, 2006 8:37 am
wow i didnt even think of checking hardware stores, i checked just about every auto parts store in my area and i even went to toyota to try and find longer ones but no luck...
i am currently working on gathering pieces to make the feed and return line braided and doing away with the stock steel lines really just to be on the safe side, plus i am going to go with the ct27 and i dont want to risk damaging it.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby 88st165 » Tue Mar 07, 2006 8:27 pm
well all ace had was exhaust studs the same length as the stock ones so that didnt work out. i removed the oil lines so i could have room to mock up the turbo and manifold and downpipe and without that spacer there would be alot more fitment issues to deal with. first would obviously be that the wastegate arm would hit the banjo bolt that is on the oil filter housing, then the wastegate actuator would hit the coolant lines, and also if you had a aftermarket downpipe that would hit the oil filter. that spacer really does save you alot of trouble.
you can see there is barely any room between the d/p (aussie) and oil filter and this is with the spacer:.... also requires you to bend the dip stick tube alittle to clear the d/p
this is the best pic i could get of the w/g actuator arm and the banjo bolt on the oil filter housing, you cant really tell but there is just enough clearence between them:
more pics:
really close to the coolant lines:
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Tue Mar 07, 2006 8:52 pm
that sucks about the studs
did you try to find a metric threaded rod ? google it and you will see what it is :D
good pics
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby klue » Thu Mar 09, 2006 11:33 pm
what if you clocked the turbo back toward the intercooler?
Postby 88st165 » Fri Mar 10, 2006 5:55 pm
saved_1992 wrote:that sucks about the studs
good pics
http://www.mmsacc-stainless.com/metric/ ... ic_rod.htm
^i called and they wanted $68!!!!! for 3ft...... WTF!
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Fri Mar 10, 2006 6:39 pm
good pics
^i called and they wanted $68!!!!! for 3ft...... WTF![/quote]
usual alltrac prices :cry: , buy it use what you need and sell the rest to the others that need the studs :wink: also check the hardware stores some sell threaded rod also
mike
omaha,ne
saved_1992
Postby klue » Tue Mar 14, 2006 3:03 am
im almost done my swap. just waiting on my gaskets. I didnt have to buy any flage"spacer" or longer studs. ive got a secret :D
after im done i got pics
Postby d1alltrac » Tue Mar 14, 2006 3:06 am
klue wrote:im almost done my swap. just waiting on my gaskets. I didnt have to buy any flage"spacer" or longer studs. ive got a secret :D
interesting...i want to know what this secret is
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby 88st165 » Tue Mar 14, 2006 7:30 am
oh now you tell us!!!!!!!! :x
:D
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Tue Mar 14, 2006 12:37 pm
I feel another write up coming on this swap :D
mike
omaha,ne
saved_1992
Postby klue » Tue Mar 14, 2006 7:00 pm
i ordered the only gaskets left in the country so its taking forever to get them. so by the end of the week i will unveil the "secret sauce"
haha
Postby 88st165 » Wed Mar 15, 2006 6:20 am
i wish you said something earlier because i am too far into gathering all the materials to really do it any other way :cry:
:shoots: $$
Black st165 - gone
88st165
Images: 2
Postby klue » Thu Mar 16, 2006 2:14 am
well id like to start doing the write up but i took about 30 pictures, and no where to host them anyone got idea?
Postby d1alltrac » Thu Mar 16, 2006 2:59 am
klue wrote:well id like to start doing the write up but i took about 30 pictures, and no where to host them anyone got idea?
http://www.imageshack.us
http://www.photobucket.com
there are a couple, both free.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby 88st165 » Mon Apr 10, 2006 1:16 am
well i finally finished after gathering all the parts and having a day off to finish up all loose ends.... sorry for so many pics...
Image Lines and flange from rabidchimp.com..... great quality!
Image longer studs cut from 3ft threaded rod and manifold spacer
Image KO racing oil feed adapter for st165.... excellent work!
Image KO racing oil pan adapter
Image modified lines from rabidchimp.com because i measured too long because i did not have the adapters at the time
Image engine bay shot
Image shot from under the car
Image battery in the trunk (just set up temporary just to see if it started and ran good, wiring will be cleaned up and hidden)
thats all i got, sorry for so many pics... i havent had a chance to drive it yet to see how well the twin entry works or made a difference... ill report back when i get a chance.
Thanks to ImageShack for Free Image Hosting
Black st165 - gone
88st165
Images: 2
Return to How To
