how to upgrade 165 turbo/ic to 2 gen turbo/205ic ** UPDATED*
Postby CryoGoblin » Mon Sep 04, 2006 6:22 am
its ok your going to get through it, :P, i managed to somehow get through it :D, just follow the site and you should make out fine, everyone here pretty much have got past all the different problems :S
~Arthur~
1988 Celica AWD
CryoGoblin
Postby d1alltrac » Mon Sep 04, 2006 6:39 am
@joel--its really not all that hard, as long as you have the spacer the only part that is even close to hard is bending the oil lines but that isnt even that bad. if you have any questions i'll be glad to help
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby //Zee-Roh// » Tue Sep 05, 2006 1:43 am
I'll definately be lookin' you up... This is starting to cost a LOT more money than I had once planned. Do you have an AIM? PM me... I have a few questions that need answering.
'88 All-trac ST165
-Joel
//Zee-Roh//
Postby 88st165 » Tue Sep 05, 2006 6:11 am
//Zee-Roh// wrote:This is starting to cost a LOT more money than I had once planned.
haha..... sadly it always does. The lines/fitting/adapters and the longer studs was the hardest and took the most time finding and aquiring. good luck and keep chipping away at it and it will be done in no time.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby //Zee-Roh// » Tue Sep 05, 2006 6:41 am
Well, I'm buying the last parts tomorrow...here goes nothin'.....
'88 All-trac ST165
-Joel
//Zee-Roh//
Postby 88st165 » Sun Sep 17, 2006 9:23 pm
oh yeah you can also use the 2nd gen heat shield if you notch out a spot for the coolant line if you are using the 1st gen coolant that goes to the rad. i was running without the heat shield and it would start to melt away the hood liner. ill get a pic up tomarrow.
Black st165 - gone
88st165
Images: 2
Postby //Zee-Roh// » Sun Sep 17, 2006 9:29 pm
Good thing I already took off my hood liner because it was crappy, eh? I'm getting an HPC coated mani, so that'll take the heat down, as well as a downpipe. Should I heat wrap the downpipe?
'88 All-trac ST165
-Joel
//Zee-Roh//
Postby 88st165 » Tue Sep 19, 2006 6:55 am
//Zee-Roh// wrote:Good thing I already took off my hood liner because it was crappy, eh? I'm getting an HPC coated mani, so that'll take the heat down, as well as a downpipe. Should I heat wrap the downpipe?
you know i was really considering heat wrapping the down pipe beacuse it is so close to the radiator. i dont remember if people recommended it or not, im going to have to do a search again, but more than likely i will end up wrapping it anyway and if the dp cracks then ill just get it welded again.
Black st165 - gone
88st165
Images: 2
Postby 5speedGT4 » Tue Sep 19, 2006 11:06 pm
i wrapped mine, no problems with 2 years of use when i owned the car
Andrew
ST165<----Sold
5speedGT4
Postby //Zee-Roh// » Tue Sep 19, 2006 11:45 pm
I'll probably end up wrapping it then...
'88 All-trac ST165
-Joel
//Zee-Roh//
Postby saved_1992 » Tue Nov 14, 2006 1:26 am
9000 hits just wanted to post :shock:
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby 88st165 » Tue Nov 14, 2006 3:48 am
^bump for the guy who started it all... :notworthy:
anyway, hows everyones twin entry swap running?
mine is running great other than a rattling issue i have to track down but other than that is good. i cant wait to get the ct27 back from ats and see how it feels.
Black st165 - gone
88st165
Images: 2
Postby d1alltrac » Tue Nov 14, 2006 11:29 pm
88st165 wrote:^bump for the guy who started it all... :notworthy:
My white one is running great, other then a couple of little things non-turbo related.
My red one (used to be saved_1992's, its the car he did the swap on when he did this write-up) has a large hole in the block. :doh: It'll be a while til I have the money for the planned 3rd gen swap. :|
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby 88st165 » Wed Nov 15, 2006 1:14 am
^Well its good to hear one is running.
So that makes 3 twin entry swap st165s accounted for since you have two of them!
I wonder how many other swaps are running around or should i dare to say "sitting around" :shrug:
Black st165 - gone
88st165
Images: 2
Postby saved_1992 » Thu Nov 16, 2006 2:29 pm
thanks :D
before you put on the ct27 consider installing some arp rod bolts (weak link in the 165) i think that is what broke on my old red 165 and put a hole in the block
mike
omaha,ne
saved_1992
Return to How To
