[How to] Pull the engine
Postby Hotrodhendrix » Fri Aug 08, 2008 7:54 pm
You can bolt a leveler directly to the engine. I dont remember which ones I used but it worked just fine.
Postby Sifu » Fri Aug 08, 2008 8:03 pm
Just don't use chains and wrap it around it... Really... its heavier than you think...
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Hotrodhendrix » Fri Aug 08, 2008 9:24 pm
Agreed my leveler has brackets that you can actually bolt directly to the engine. Do NOT rig anything when your trying to remove an engine.
Postby compy591 » Fri Nov 14, 2008 7:44 pm
As far as doing this just in a garage at home, how are you lifting the front end of your car high enough to lower the engine out completely? Any proven/preferable methods for this?
compy591
Postby LegacyofDan » Fri Nov 14, 2008 7:53 pm
compy591 wrote:As far as doing this just in a garage at home, how are you lifting the front end of your car high enough to lower the engine out completely? Any proven/preferable methods for this?
that is what i did...let the engine sit on to a lil short push cart thing and then lifted the body up and pulled the motor...it was one of those bunny in the hat sort of occurances
Postby Corey » Fri Nov 14, 2008 9:08 pm
See Page 1
Corey
Images: 50
Postby mx6er2587 » Wed Nov 26, 2008 12:23 pm
so it looks like posts have been delted in this thread. Was it ever stated how to lift the car high enough to get the engine out? From two of the pictures it looks like chains wrapped around the bumber support? Will that work with the rc support?
mx6er2587
Postby Sifu » Fri Nov 06, 2009 7:30 pm
I should have put these here a while back...
Transaxle "Missle Silo Method"
This is the hardest part. Making sure that this clears. As you can see there was a lot of fighting w/ all that scraping and getting stuck. You should try to twist and be very careful not to have any fingers getting pinched.
Basically let gravity do the work. Put a piece of carpet on the ground and lay the engine flat on the cam cover side. Take off your powersteering idle valve/bypass valve as those are made of plastic and break easily (replacement is like $80 for the bypass valve, you know, Toyota prices). Carefully lift up the tranny and manuever it over the tranny shaft.
Drop it and twist. Sometimes it's easy to get some rope and put it in the screw holes so you can angle that but I've always been able to drop it onto it w/ no problems. When you can get a screw through the bolting points then do so leaving some slack. Manuever that beast carefully and slowly. It will drop into place.
*** There are other ways of doing this that are easier and less damaging to the brittle pieces but you would need to get both parts sitting on something sturdy and mate them together. You get the idea...
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Corey » Fri Nov 06, 2009 9:30 pm
I suggest a wooden pallet to place the tranny onto. Then hoist the motor to mate up with the tranny.
When I did mine this way, It took 3 people to muscle it on and line it all up.
I considered the silo method, but it was a bit intimidating for me :oops:
Corey
Images: 50
Postby Terracar » Fri Nov 06, 2009 10:15 pm
Personally I recommend the BMB method - Big Muthatrucking Bolt.
I will get some pics, but was able to one man it and get it done in about 10mins without worrying about it all crashing down.
Terracar
Postby mx6er2587 » Mon Nov 09, 2009 7:35 am
I tried the big bolt method, in fact I believe I was able to get at least 4 bolts in, and still was unable to get the tranny to mate. My friend and I were baffled. We spent a good 4 hours twisting and shaking and trying different bolt locations.
Missile silo took about 15 mins. I don't think we put a single scrape in the tranny like sifu is showing.
We placed the engine down (cam cover off and of course the power steering idle up removed, that guy should be gone before you even try to drop the engine) on an old tire. We left it chained to the hoist in case of catastrophic failure (you know like falling on our feet while holding a f***ing heavy transmission above it)
The two of us lifted the tranny and manhandled it into place and shook for a bit. Couldn't get it so we pulled it back off, realigned and tried again. A bit more shaking and it slid perfectly.
mx6er2587
Postby Sifu » Mon Nov 09, 2009 11:39 am
Good work! I did it all by myself though... :P All my pulls usually are... :lol: :twisted: :shoots: :evil:
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Terracar » Mon Nov 09, 2009 1:20 pm
For the BMB method (bolt method) I used the bolts that held the engine to the engine stand - they were a nice length.
There are 2 key points with the bolt method:
1. You have to have the transmission in gear.
2. You have to have the driveline (or axle- driveline is easiest) in place
You line the engine and trans up as best you can. I had engine on some sturdy blocks with some shims to have it at same angle as the trans. The transmission was on the engine hoist.
Lower the trans and mate it as best as you can to the engine. (remember the way BGB says to remove it - it helps) Cinch up the bolts by hand checking to make sure the output shaft is aligned with clutch. Tighten bolts by hand; once you start getting resistance turn the driveline.
This is wear the trans needs to be in gear - to turn the output shaft to align the splines. Will take a few moments, but you can feel when the splines line up. Keep tightening the bolts up , by hand, using washers/spacers as needed until you can use the real bolts.
Keep in mind by hand can also mean a short stubby ratchet - just be sure ot to over tighten.
Tips:
1. patience
2. You have to have the transmission in gear.
3. You have to have the driveline (or axle- driveline is easiest) in place
4. re-do the spaces/washers on teh bolts frequently as they can only go into the block so far.
5. patience
6. Keep checking alignment of output shaft.
7. patience
Terracar
Re: [How to] Pull the engine
Postby TRDTurko » Thu May 19, 2011 10:47 pm
I am surprised I havn't seen this question yet: How come you cant pull the motor out from the top? my toyota repair manual says you can.
88 Celica GTS - RIP
93 Honda Civic - RIP
85 Honda Civic - Sold
08 Mazda 3 - Daily
TRDTurko
Postby alltracst185 » Thu May 19, 2011 10:54 pm
TRDTurko wrote:I am surprised I havn't seen this question yet: How come you cant pull the motor out from the top? my toyota repair manual says you can.
You can, it's just harder and more of a risk
alltracst185
Return to How To
