[How To] Remove Front Axle (video)
Postby zak062 » Sat Nov 29, 2008 6:29 pm
Its split into 4 sections because of size/length.
1
2
3
4
03 Subaru wrx(DD) My first non-toyota
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
88 alltrac, blue (Project)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
[img]http://img263.imageshack.us/img263/3199/zac062copyto3.jpg[/img]
Finaly got an all-trac :)
zak062
Postby TomsGT4 » Sat Nov 29, 2008 7:20 pm
Exactly for that reason (because it happened to me) I leave the tie rod end attached to the carrier and remove the bolts from the strut tower & lower ball joint, then swing the carrier out enough to pop the axle out of the tranny.
Interesting way of keeping the rotor from spinning when breaking the axle nut free. But if it's possible to remove the center cap on your mag/wheel? I like to loosen it with all4 wheels on the ground.
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Postby Rick89GTS » Sat Nov 29, 2008 10:57 pm
TomsGT4 wrote:.......But if it's possible to remove the center cap on your mag/wheel? I like to loosen it with all4 wheels on the ground.
Yes, you can reach the axle nut if you remove the center cap. Then you can loosen it while the car is sitting on all fours. That's how I do it, easier for me that way :)
Rick89GTS
Postby zak062 » Sat Nov 29, 2008 11:24 pm
i've done it this way probably near a dozen times. Works best for me now.
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Postby Rick89GTS » Sat Nov 29, 2008 11:39 pm
Zak, from the vid, I couldn't see exactly where you put that wrench. Did you just jam it between the rotor and brake pad?
Rick89GTS
Postby zak062 » Sat Nov 29, 2008 11:41 pm
in the vents on the rotors
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
zak062
Postby Rick89GTS » Sun Nov 30, 2008 12:05 am
Ahh, I see......thanks, I'll have to try that method. :)
Rick89GTS
Return to How To
