[How to] Create a custom mount for an HKS EVC 3
Postby Dups90gt » Sun Jan 18, 2009 2:06 pm
Here's a how to to create your own custom mount for any boost controller, this is just a guide for an EVC 3 but the shape can be anything anywhere on your car.
oh no another picture filled project by Fernando!
So I received my HKS Boost Controller and was looking for a place to mount it. I wanted it to look stock or as close to stock as possible. I was thinking of mounting it in the spare radio compartment but then thought what if I get a double din stereo later on.. then the cup holder, I could install my boost controller and my turbo timer there but I don't think I could live without my cup holders.. so there's the ash tray, humm I would have to close it off and make a mount and a hole for the controller but It looked like a good spot.
Its freezing out and I don't have a garage so I had to work with what I had. short strand fiber, first I removed the housing and unscrewed the ashtray mount.
found some plastic from an old box of clips and cut it to cover the hole. User plastic as fiberglass does not stick to plastic and it will be smooth.
Here is my small table and the bezel and the plastic and a pair of scissors a blade, tape (ok so I didnt have masking tape but had a lot of Christmas wrapping tape..so I used that) Newspaper tin foil and a marker.
Cut the plastic to cover the ashtray hole.
Test fit it so it covers the entire hole.
cut a hole out for the controller
Tape it onto the bezel (try and use masking tape.. much better, only plus is that fiberglass does not stick to it at all)
wrap you controller in foil and tape it up, we need to make a perfect mold for the controller so we dont have to make a mount.
get a piece of dense foam and cut out a section for the controller , we will use this to press down on the mold.
Pop open your glass.
Oh shit dont forget to cover your work area .
Test fit it on the foam.
Take a 'Jackie Chan' Book and flip enough pages to balance the rear of the bezel.
Grab a plastic container (You can use the lid but I needed it to pour in later.
Scoop some glass into the container,
add hardener
mixed, the more hardener the faster it will harden, I put alot coz it smells so bad and Im inside the house. (wife not home yet)
I put the controller wrapped in foil in the mold and then poured in the glass mixture, let it dry for a bit (3 min) then pulled out the controller but left the foil (glass gets hot as it dries and I didnt want the controller to melt), and please no one hack on me for using the Bible to weigh it down, it was the heaviest book in the house.
pour it in and push the stick up and down as you pour to get rid of bubbles, make sure you get it all in the corners.
Weigh it all down while it dries (approx 40 mins)
wait....
wait........
wait............
3 spongebob episodes later..
time to test the hardness... solid as a rock but still soft enough to shape a little
Flip it over WOW HOW SMOOTH, the trick of plastic on glass..
Peel off the plastic and tape
See smooth..
Peel off the foil mold and cut off the excess glass (careful its sharp)
OK test fit the controller - PERFECT FIT, it even clicks in place.
Time to sand it down and make it real smooth. wet sand it under a sing with 800 grit water proof sand paper.
here it is so far.
I added another layer around the hole as it looks terrible, Ill sand it again and paint it tomorrow as I dont have paint.
TO BE CONTINUED TOMORROW.
total time to build 2hrs 42mins.
Dups90gt
Postby Dups90gt » Sun Jan 18, 2009 2:07 pm
ok so her we go.
After sanding down the 2nd glass coating its time to test fit again, look how crappy the opening looks, not to stock looking.
time to get out the bondo and fill in the gaps .
first pull out the controller and tape it up, tape the edges you want as the size of the opening so it sticks out.
then put it back in and mix your mud, I only used a tiny bit of hardener coz I need more time to work with the mud.
here it is taped with a layer of mud on it.
cut along the edges of where you want the controller to stick out with a blade then remove the controller. Here it is sanded down.
now fix the hole where the controller will go with sand paper, be careful to to sand down too much! and keep test fitting.
Now we have the shape but bondo is not smooth even if sanded with high grit sand paper, you need to use glaze putty on it.
squeeze out some putty on a spatula and spread it on the pits and scrapes left behind by the sand paper.
spread it thin! it will crack if you spread it thick! bondo is spread thick, putty is thin.
after wet sanding it in the sink and getting it smooth, I brought it to the stairwell to paint (hehe) flat black, if you want semi gloss get gloss and spray it when its freezing outside, it will turn whitish then go semi gloss later.
after drying I test fit it in....
PERFECT FIT!
so what did I learn from this?
..............that I'm TOTALLY AWESOME!! Image
Total time from start to finish.
approx. 6 hours all in my condo. would have been faster if I had a garage.
Dups90gt
Postby LegacyofDan » Sun Jan 18, 2009 6:40 pm
Wow very nice bro, i saw the first pics, and was like uh oh i hope this turns out good and then at the end i was like holy shit that look sick! VERY nice indeed! :)
Postby edmonton_oiler16 » Fri Jan 23, 2009 6:29 am
cool cool great job you definatly need to post some pics of it in the car
1991 Celica GT-FOUR RC
St. Paul, Alberta, Canada
Project: http://alltrac.net/phpBB2/viewtopic.php?t=30790
edmonton_oiler16
Re: [How to] Create a custom mount for an HKS EVC 3
Postby monkninja » Thu Apr 05, 2012 5:02 pm
Dang excellent work! About how much did all of the supplies cost if you don't mind me asking? It looks fantastic!
Kyle
Kyle
1990 AllTrac
1999 Kawasaki ZX9R (Usual daily driver)
2003 Matrix Xrs (Wife's car)
monkninja
Postby Dups90gt » Mon Aug 06, 2012 12:09 pm
sorry for the really late reply, i haven't been here much and just pop in from time to time. Total cost of materials was roughly approx less then $50. I had most of the materials at home from previous projects. When you buy glaze putty, dont buy the junk in tubes like I did. Get the stuff that you have to mix... so much better and spreads much better and is easier to sand. Its called flowable glaze putty and its green with blue hardener. looks like a soft short bottle with a springgy thing on top to pump out the glaze. ill take pics if I have time later.
Dups90gt
Return to How To
