[How to] Do a turbo rebuild
Postby Minnesota91alltrac » Thu Mar 12, 2009 5:36 pm
Just thought if anyone has done this and has pics it would be an awesome thread
Minnesota91alltrac
Postby wannabe toms racer » Tue Mar 17, 2009 4:04 pm
BUMPSKIS!!!
not all of us can afford 700 bucks for a rebuild :D
Adam 'Akiba' Armstrong
90 audi 80 quattro- new projekt
Stubborn ass '91 alltrac - traded!
dont let ANYONE fool you money CAN buy happiness...
OR at least SUPPORT it...
wannabe toms racer
Images: 4
Postby Kcman91gts » Sun Mar 22, 2009 12:47 am
As soon as my ct26 bites the dust ill be more than happy to do a rebuild for this thread.
Kcman91gts
Postby LegacyofDan » Sun Mar 22, 2009 3:36 am
http://cgi.ebay.com/ebaymotors/Toyota-C ... QQtcZphoto
and u cant do a turbo rebuild on your own. unless you have the proper balancing tools.
Postby Minnesota91alltrac » Sun Mar 22, 2009 6:13 am
This form was not suggesting balancing... Obviously that cannot be done unless you own a garage or are dumb enough to buy a machine to do it for you. So lets step a side the obvious facts " no you cant spin a turbo at high RPM to balance it yourself.". This was meant just for the base parts that go bad. I thought that was easy to get.
1991 ST185 (Parting Out) :(
1987 conquest (sold) ;-(
1993 Celica GT-S (sold)
2000 F150 (sold)
1993 Chevy cheyenne (sold)
2007 Audi A4 Quattro-next step
:evil: <-thats me if you were wondering. :lol:
Minnesota91alltrac
Postby Minnesota91alltrac » Sun Mar 22, 2009 6:14 am
2000 F150 (sold)
Minnesota91alltrac
Postby Sang » Fri Aug 28, 2009 4:23 am
LegacyofDan wrote:http://cgi.ebay.com/ebaymotors/Toyota-CT20-CT26-MAJOR-TURBO-TURBOCHARGER-REBUILD-USA_W0QQcmdZViewItemQQ_trksidZp1742Q2em153Q2el1262QQcategoryZ33742QQihZ021QQitemZ310129658075QQtcZphoto
Not all turbos require balancing after final assembly. MHI (Mitsubishi turbos) are component balanced (each part is balanced separately). Therefore, you can rebuild mitsu turbos in your garage in 0.5 to 1 hr, put it all back together and reinstall. Assuming all you have to do replace the seals, bearings and washers. Should you have damaged to the wheel, shaft, et cetera...you'll have to order more parts.
Just make sure you buy a quality rebuilt kit (ebay is not a source of quality parts...). I just got my shipment for a td06 rebuild from gpopshop.com in the mail today.
Sang
Re: [How to] Do a turbo rebuild
Postby siralys » Sat Jan 23, 2010 1:09 am
I rebuilt mine and have absolutely no problems. Spools faster and no vibrations at 12psi. Let me know if you have any questions
2003 hyundai santa fe- daily driver
1995 vw passat vr6- modded wagon- sold
1988 celica alltrac- in parts finding mode
siralys
Postby MWP » Mon Jan 25, 2010 1:02 am
I rebuilt my CT26 myself too.
$100 (AU) kit from ebay, 1/2 day to remove the turbo, 1 day to rebuild it, 1/2 day to put the turbo back on.
Was whistling like a kettle when cold beforehand, now all fixed.
Spools a little quicker, is still good for 16psi and no oil leaks.
I had no problem rebuilding it myself, but i do have a 1/2 decent set of tools.
Difficult bit was splitting the core from the exhaust housing, rest was easy.
As for the balancing issue, mark the comp wheel to the shaft before disassembly and youll be fine.
Pulling it apart
Old bearings
Old thrust plate
New bearings, seals & thrust plate installed and reassembled
Postby siralys » Mon Jan 25, 2010 1:35 am
Yeah, I marked mine too and I definately agree that getting the center section split was by far the hardest part. Good that you took pics, I did mine 5 mins at a time in between apointments at our shop so didnt get any.
siralys
Postby bloodMoney » Thu Jan 28, 2010 6:18 pm
This is a great start, but I'd love to see some detailed process pics though.... I've got 3 turbos sitting at home that need rebuilds...
~bloodMoney
88 ST165 'Patty'
90 ST185 'Ellie'
'96 GT "Abby" ~ RIP 11/17/2013
'96 GT 'vert "Lily" ~ RIP 08/22/2015
'04 LS430 "Alice"
'98 GS400
bloodMoney
Postby 88st165 » Sat Jan 30, 2010 5:35 am
Its super easy to seperate the center from the turbine housing if you heat the joint with a torch, heat gun, even a hair dryer.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby MWP » Sun Jan 31, 2010 12:56 am
88st165 wrote:Its super easy to seperate the center from the turbine housing if you heat the joint with a torch, heat gun, even a hair dryer.
I heated mine with a blow torch and it didnt help much.
It depends how old the turbo is, etc.
I ended up using a old wood chisel and hammer to get them apart.
Postby Jason88AllTrac » Thu Mar 18, 2010 10:32 pm
White 88' ST165 :: Blue 88' ST165
Jason88AllTrac
Postby yellowtuner » Sun May 23, 2010 5:55 pm
Can anyone tell me where to get the parts I need to rebuild my turbo on my 90 st185t? And how much did it cost you?
03 gts yellow, 90 alltrac dark grey
yellowtuner
Return to How To
