how to install new downpipe
Postby N.W. 92 GT-S » Sat Mar 21, 2009 12:21 am
just picked up a Berk downpipe for my st185 with st205 swap. what is it gonna take to install it........ thanks
N.W. 92 GT-S
Postby alltracst185 » Sat Mar 21, 2009 12:47 am
did you make sure to get the down pipe for the ct20 and not ct26? if so it's a fairly easy task if you have any wrenching experience. Basically loosen all the exhaust side bolts from the turbo and the three exhaust bolts on the mid pipe to down pipe section. If the down pipe bracket is installed then that also has to be removed along with the o2 sensor. Hope that helps!
alltracst185
Postby N.W. 92 GT-S » Sat Mar 21, 2009 1:22 am
yep its made for a ct20b. sounds pretty straight forward. should I hit the bolts with some penatrating oil first ....... thanks
N.W. 92 GT-S
Postby compy591 » Sat Mar 21, 2009 1:27 am
Might as well trying just taking them off first, I know mine all came of fairly easily. If that doesn't work, or you just want to go ahead and penetration oil them anyway, then go for it. As far as installing it, it is very straightforward. Good luck!
compy591
Postby alltracst185 » Sat Mar 21, 2009 1:39 am
Yes, hit them with some pb blaster....i love that stuff :wink:
alltracst185
Postby N.W. 92 GT-S » Sat Mar 21, 2009 1:44 am
bp blaster ?
N.W. 92 GT-S
Postby alltracst185 » Sat Mar 21, 2009 1:46 am
It's like wd40 but better :P
alltracst185
Postby N.W. 92 GT-S » Sat Mar 21, 2009 1:48 am
oh, ok .... thanks
N.W. 92 GT-S
Postby WarTowels » Sat Mar 21, 2009 3:08 am
I would NOT try them first, even if they did by chance, come off easy.
There is no loss in putting PB Blater one, but if you try to hard on un PB'd bolts your risk breaking something.
My DP replacement was not fun. I had to remove my old stock one which was basically welded on with rust. I ended up cutting most of it off.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby compy591 » Sat Mar 21, 2009 7:40 pm
WarTowels wrote:I would NOT try them first, even if they did by chance, come off easy.
-Towels
Dang, mine came off like nothing. It was actually one of the only thing I have NOT had to use penetrating oil/fire to get off.
compy591
Postby gt4me123 » Wed Apr 08, 2009 6:02 am
Is there enough room in the engine bay of a 185 to just take off the heat shield on the exhaust manifold and work from there? or does alot of stuff have to be moved out of the way?
gt4me123
Postby compy591 » Wed Apr 08, 2009 12:40 pm
Well, on my 165 I just unbolted the DP from both sides, turbo and midpipe, took off the O2 sensor, and dropped the DP down, it seemed pretty simple. You could probably do something similar.
compy591
Postby TRDcelica90 » Thu Apr 23, 2009 3:37 am
Hmmm dump pipes my next mod and the lower bolt on the heat shield is rusted and rounded. cant get the bitch off. tried sockets, WD-40 and pliers its in there pretty good.. will i need to get the heatshield off?
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90
Postby Chai » Sun Apr 26, 2009 1:40 am
TRDcelica90 wrote:Hmmm dump pipes my next mod and the lower bolt on the heat shield is rusted and rounded. cant get the bitch off. tried sockets, WD-40 and pliers its in there pretty good.. will i need to get the heatshield off?
try a cutting wheel. or if not that and you don't want the heat shield anymore just bend and pull and do what ever till it breaks off.
Chai
ST-185
"Man can hold the world in his palm if he first learns how to unclench his fist."
Chai
Return to How To
