Engine harness removal
Postby N.W. 92 GT-S » Sun Apr 26, 2009 10:06 pm
Had a member here do a st205 swap into my alltrac. I was having a ems install yeaserday and when we pull on the harness some wires came apart. The guy who done the swap used butt connectors and took the insulation off sections of other wires to tap into them, no soder or even electrical tape WTF!!
Looking at this made to wonder wtf the rest of the wiring looks like.
I need so tips on removing the entire harness and having it reworked correctly .... thanks
N.W. 92 GT-S
Postby Sifu » Sun Apr 26, 2009 11:15 pm
This is what I would do. Excessive yes, but hey nothing is worse than trying to flag down unknown connections.
- Unplug all the harnesses from the ECU side
- Remove the passenger side glove compartment
- Run the loom through and under the AC into the firewall that goes into the engine
- Unbolt the engine at the mounting points
- Lift up the engine slowly, drop it and pull out engine
- Pull off harness and inspect
You could try to unplug everything from the engine and pull it thru the firewall but who knows what you may lose or snag/tear/break.
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby N.W. 92 GT-S » Sun Apr 26, 2009 11:25 pm
yea im thinking this would be the best route also ...... thanks
N.W. 92 GT-S
Return to How To
