Is it possible?
Is it possible?
Postby Tarmac_St165 » Sat Jan 02, 2010 8:52 pm
I need to drop my transmission to change out my flywheel. (Some teeth are broken it doesnt start sometimes.) I want to just drop the trans, not sure if this is possible I have looked around but only found talk of people dropping everything threw the bottom. Is this possible?
Lower, Louder, Wider, Faster.
Forever Young
Tarmac_St165
Re: Is it possible?
Postby paladek » Sat Jan 02, 2010 10:44 pm
Hey,
short answer.....No, that's not possible......
You have to take the whole thing (engine+tranny...) out.....
regards
paladek
Re: Is it possible?
Postby DeeCee » Sat Jan 02, 2010 11:20 pm
The BGB explains how to drop the transmission out without taking the engine out. This is what they did to repair my gearbox a couple of years back.
To only drop the transmission is around 8 - 10 hours or so. The ideal way is to drop the engine and gearbox together as it saves a couple of hours and a lot of fiddling around.
DeeCee
Re: Is it possible?
Postby Tarmac_St165 » Sat Jan 02, 2010 11:53 pm
Hmmm thanks. I think ill wait to do this till I have money for lightweight flywheel new clutch and such things. I dont think I will want to do this too many times lol.
Forever Young
Tarmac_St165
Re: Is it possible?
Postby paladek » Mon Jan 04, 2010 2:07 am
Hey DeeCee,
Can you please point me to the BGB section where it explains how to replace the clutch (for example...) without taking to whole thing, engine and tranny out of the car....that would be an interesting reading for me....?????
regards,
paladek
Re: Is it possible?
Postby DeeCee » Mon Jan 04, 2010 3:02 am
just searched through the st185 and st205 bgb's and couldn't find it. I must have been mistaken. Maybe it was from what the mechanics told me.
It was something like - take out bottom undertrays (and whatever else i guess lol), take off dump and mid pipe, remove prop shaft, remove transfer case mount, loosen gearbox mounts, loosen and remove gearbox/engine bolts, remove engine mount, tip to the side and take off box/diff/transfer. I'm not sure how they did it exactly, but they did manage to do it all while leaving the engine in the car. Probably helped that they had a car hoist and lots of heavy duty stands that could take the weight of the engine being tipped and moved around lol.
DeeCee
Re: Is it possible?
Postby Shaggz00 » Mon Jan 04, 2010 4:16 pm
it is 100% possible to remove the trans by itself, we've done it numerous times. This past time, which was about a month ago, we went from 100% assembled, to out, in an hour and 45 mins. BUT, we have a lift and trans jacks. Basically, you hang the engine off the timing belt side engine mount (it can suppot the weight, I assure you). If it's something you wanna try, then PM me, and I'll write you a step by step.
-Avi-
Shaggz00
Re: Is it possible?
Postby Rpz123isme » Mon Jan 04, 2010 5:47 pm
I can see it being dropped in an hour and 45 mins. but how long to put it back in. when i did my first alltrac clutch i dropped just the trans, when it came to putting it back i spent an entire day trying befor i decided to just drop the motor and it was still a bitch to line it back up.
Hesperia, CA
Rpz123isme
Re: Is it possible?
Postby Tarmac_St165 » Mon Jan 04, 2010 6:54 pm
If and when I do decide to tackle this it will be in my garage with no lift just jacks and stands. I guess my car is going to keep its starting problem for now. Pm'd about the step by step for future use.
Forever Young
Tarmac_St165
Re: Is it possible?
Postby ChrisD » Mon Jan 04, 2010 9:03 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Re: Is it possible?
Postby DeeCee » Mon Jan 04, 2010 9:18 pm
if in the garage, drop the whole lot onto a dolly and wheel out from underneath. It will save a pile of cursing and time in the long run.
DeeCee
Re: Is it possible?
Postby banshee 101 » Fri Sep 03, 2010 12:24 am
like most people have said, it is possible to drop just the tranny but also a pain in the ass, i have done this twice.
i suggest like most other people do, drop the whole engine
91 ST185 JDM
w/ Mods
banshee 101
Re: Is it possible?
Postby SleepingTurbo » Thu Jan 06, 2011 1:35 am
ummm ive done it. dropped just the trans. its not the easiest thing in the world but it is possible. took me about 4hours with some help, a lift and a trans jack.
May be moving on from the All Trac world.
SleepingTurbo
Re: Is it possible?
Postby AvivB » Thu Jan 06, 2011 12:54 pm
I'm not sure how complex it is in the AWD models, but in my FWD model I've replaced the clutch in less than 2 hours (with the help of a very good mechanic)...
/Aviv
('92 ST182RC 1/1 :-) )
AvivB
Return to How To
