st205 WTA in st165
st205 WTA in st165
Postby IStalkgt4s » Sun Jan 03, 2010 9:02 am
i have a st205 WTA with the piping and heat exchanger, and i am looking to put it into my 88 165.the engines been swapped with a jdm 185. my question is, can i throw the intake manifold and TB from a 205 on my block instead of fabing a plate and using a autozone coupling? cause i would like to have it free flow and not get restricted by the smaller TB. Also, how to i set up the temp sensor on the WTA unit, and the hood should have enough clearance right? I am pretty sure i can get it on no prob, but id rather do it right then jimmy rig it.and if anyone has the intake manifold and TB from a 205 they are trying to sell, let me know. any input is appreciated... thanks
1990 st185 -Jayne- (Project)
1988 st165 -Susan- Daily Driver
2008 Tacoma -Maria- PreRunner
IStalkgt4s
Re: st205 WTA in st165
Postby d1alltrac » Sun Jan 03, 2010 9:35 am
-gen3 intake manifold won't fit gen2 head, I don't know about the TB.
-that is a water level sensor, not water temp
-hood clearance is tight but it should fit, you might have a little rubbing in a couple areas
-you will have to modify the intercooler inlet, the inlet/outlet are spaced differently than 165/185
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby IStalkgt4s » Fri Jan 15, 2010 2:45 am
Thanks good to know, Kris at KO racing is gonna make me a adapter for it so hopefully that goes well.
IStalkgt4s
Return to How To
