AIT and MAP sensor wiring
Postby alltracst185 » Sat May 21, 2011 1:46 pm
Ok I decided to do a write-up on this since it was very hard to find any info on the matter. I had it almost done but then clicked off backspaced and lost all that I have done :doh: So this is my second time around :P
Tools you will need:
1.) electrical tape
2.) soldering gun and solder
3.) razor knife
4.) heat shrink wire wrap
5.) scissors
6.) lighter or heat gun
AIT is up first:
First you want to locate the AFM plug and cut it off. It will have four wires (Pink, Brown, Gray and a Gray/Black) Then you want to strip all of the tape and plastic covering off up to the plastic peice near the injectors. Once you have that done, take and free all wires from the harness. The Pink will free up untill it meets with the other pink wire. Cut it off and tape it up good because you will not need it. Here is a pic of where they meet
Now take the Brown and Gray/Black wire and run them to a desired spot where you will be mounting the AIT sensor (most use where the cold start injector would be if still using the stock manifold and throttle body) Or if not, anywhere on the intake manifold or throttle body. Make sure that the sensor mounting point is deep enough so that the sensor is protruding in to get airflow over it. Now you will notice you still have a solid Gray wire left over, just cut it off or tuck it away somewhere because it will also not be needed.
So on to the wiring, take the Brown and Gray/Black wires and attach them to the two AIT sensor wires (polarity does not matter) Solder them together and heat shrink wrap them. Tape them up ensuring a good seal. What you have now should look like this pic:
Do not tape up the harness as you will need it stripped for the MAP sensor wiring :wink:
Now for the MAP sensor:
Locate the turbo pressure sensor. It will have three wires, a Pink/Blue,Brown and a Red/White. Here is a pic:
Cut the clip off. Strip back and run wires to a desired spot, again on the intake manifold. Now take the MAP sensor Red wire and attach to the Pink/Blue OEM harness wire. Take the MAP Black wire and attach it to the Brown OEM harness wire. Lastly take the MAP Green wire and attach it to the Red/White OEM harness wire.
Solder, heat shrink wrap and tape up all three wires. Wiring is done :D What you have now should look something like this pic:
Wrap up the whole harness with the electrical tape and re-use the plasic covering then you are done!
st185- HKS exhaust, Aussie mid pipe and custom 3" down pipe, Tial 50mm BOV, HKS 272 cams, HKS adj cam gears, custom FMIC, HKS GT3040, Tial 38mm wastegate, AEM ems, fully built bottom end, RC 1200cc injectors, at 25 lbs and almost complete :D
alltracst185
Re: AIT and MAP sensor wiring
Postby l0ch0w » Tue Sep 06, 2011 5:08 am
Did you solder those wires???
Andrew
1991 Red Alltrac
Frankenstein engine, lots of mods :P
l0ch0w
Postby alltracst185 » Tue Sep 06, 2011 8:05 pm
Yes, just didn't take a pic
alltracst185
Postby UtahSleeper » Tue Sep 06, 2011 8:12 pm
So, is this so you can remove the MAF on the 165 and 185 and keep the ECU working right?
UtahSleeper
Postby alltracst185 » Tue Sep 06, 2011 8:36 pm
This is for wiring in AIT and MAP sensors when using a EMS, dont really know if it will work with the stock ECU :shrug:
alltracst185
Postby darkcloud350 » Tue Mar 27, 2012 10:25 am
Has anyone tried this with the stock ecu
darkcloud350
Postby l0ch0w » Tue Mar 27, 2012 7:00 pm
Wont work with stock ECU... MAP based ECU's are TOTALLY different than VAFM type load maps....
Andrew
1991 Red Alltrac
l0ch0w
Postby darkcloud350 » Wed Mar 28, 2012 4:14 am
How would I go about map on my 90 I want to delete the maf
darkcloud350
Postby jeffrosie » Tue May 01, 2012 7:46 pm
Thanks for such a detailed writeup :)
Now only to find how to rewire the ST185 to work with the 205 ECU, obv with 205 injectors ana map sensor.
jeffrosie
Postby UtahSleeper » Tue May 01, 2012 8:29 pm
darkcloud350 wrote:How would I go about map on my 90 I want to delete the maf
Aftermarket ECU or later gen electronics to delete the MAF.
UtahSleeper
Return to How To
