How to install a catch can
Postby st165-alltrac » Sun Aug 14, 2011 9:39 pm
I'm have issues with oil in my turbo/tmic and am thinking of installing a catch can to help. Can any one explain how this is done or have any pictures of it?
Got my first All-Trac at the age of 17
ST-165 W/ ST185 swap -sold
Will return to the All-Trac world, but next time with a trac that runs
st165-alltrac
Re: How to install a catch can
Postby the converted » Sun Aug 14, 2011 10:02 pm
For what you are describing, I don't think that a catch can will really help out that much. They are designed to collect blow-by from the pcv system, but what you are describing sounds like leaking oil seals in the turbo itself. Doing a rebuild will probably get you all straightened out.
the converted
Postby alltracst185 » Sun Aug 14, 2011 11:12 pm
There are two hoses that need to go to it, first you take the one from the valve cover and run it to the catch can, then run a second hose from the other catch can port to the intake. Remember to keep the catch can lower than the crank case vent line so blow by will go into the catch can.
Here is a pic of my engine bay (st185) in the works but shows a good visual of how to run a catch can.
alltracst185
Postby st165-alltrac » Mon Aug 15, 2011 4:23 am
Yeah I was thinkin of gettin a ct26 from somebody? How can I check it to make sure the turbo isn't a POS. I know I need to check for cracks but what else should look for or check?
BTW alltracst185 I want your engine!
st165-alltrac
Postby alltracst185 » Tue Aug 16, 2011 12:27 am
Check for shaft play and marks caused by the turbine wheel rubbing the housing.
Thanks, I have been building my trac for two and a half years now and she is just about done :D
alltracst185
Postby Xiansheng » Tue Aug 16, 2011 1:22 am
st165-alltrac wrote:BTW alltracst185 I want your engine!
You can say that again!
Thanks for pic man! I also wanna setup a catch can, before I NEED to setup a catch can. :wink:
(one of the things on my list anyway... lol ..'THE LIST' :twisted: )
'91 GT-Four RC
Xiansheng
Postby DudeMan » Wed Aug 17, 2011 9:31 pm
I know this is off topic but why do you still have the ABS relays if the rest of it is gone?
Its the little unit with two electrical plugs right under the power steering reservoir.
Back on topic, you can use an air compressor filter as a DIY catch can if money is low..
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby jonnyboygt4 » Wed Aug 17, 2011 10:39 pm
ebay has catch can kits that come with everything you need for about 30 bucks or cheaper...in the alltrac world it dont get any cheaper than that!
like dudeman said...you can use a air compressor water/oil seperator but it'll still cost you 20 bucks at home depot versus a nicesly made catch can on ebay...i bought one off ebay and it worked well and was made well too...
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Postby alltracst185 » Thu Aug 18, 2011 12:17 am
DudeMan wrote:I know this is off topic but why do you still have the ABS relays if the rest of it is gone?
Didn't know what they were at first (old pic), they are gone now :wink:
alltracst185
Postby DudeMan » Thu Aug 18, 2011 3:39 am
Gotcha, I'll sleep better tonight. :D
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Return to How To
