How do I delete the power steering
Postby celigts » Fri Jan 13, 2012 10:27 am
As the title says I'm looking to delete my power steering. Since I bought the car it was leaking like mad and had my belt removed when I had the swap. So I'm use to it and just can't see me adding it again so I wanna take out the hardware now.
Anyone know what I can and can't remove? And how do I properly close the pump switch hose?
Let me know. Thanks alot !
3SGTE project motor very slow
celigts
Postby celigts » Wed Jan 18, 2012 1:44 am
Can anyone help me out?
Would I be able to at least remove the oil container and lines from it. I know I can't remove the pump.
Anyone please.
celigts
Re: How do I delete the power steering
Postby DudeMan » Wed Jan 18, 2012 2:42 am
I don't get it, why didn't you just fix the leak when you swapped in a new engine?
You don't need the pump if there's no belt on it or fluid in the system.. you can take out the reservoir and lines too.
The real problem is the rack. You need one designed for manual steering, not power.
Really though, it would be both cheaper and easier to just fix the leak then convert to manual steering. Its not like your going to save any time or money, so why bother?
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby 4rsnduction » Wed Jan 18, 2012 3:01 am
I had the same problem for the last year, I was running with no power steering because the return hose split so i had to cut the belt to save the pump, drove around with no power steering for a full year before I finally got it fixed.
I must say the handling of the car has changed dramatically, i have less confidence in the car around faster corners, the weight transition is sharper/faster. once you get used to the no power steering its not to bad unless your doing a 3point turn in a tight driveway, but its a strange feeling to get your power steering back, like i said, no more confidence once i got it back :(
The most important issue will always remain....your still using a steering rack designed for power assistance.
Not the same as a manual steering rack at all.
Plus without the power steering working u can notice the worn out universal joint in the steering colum alot more than usual and replacing this is a PITA +5
4rsnduction
Postby brutekiller787 » Wed Jan 18, 2012 6:29 pm
pretty simple to do the outside stuff, complicated to make it work correctly. you actually need to cut off the seals inside the rack that keep fluid on one side or another in order to have a true manual rack. there was a write up on a miata forum i think, with pictures and everything. let me see if i can find it...
Edit: google and 3 minutes = http://www.flyinmiata.com/tech/depower.php?x=1
a good read even if it doesn't seem like your cup of tea
brutekiller787
Postby lumbercis » Wed Jan 18, 2012 11:34 pm
Just fix it. If your steering wheel broke would you remove that too? :P
Caldina powered...
lumbercis
Postby celigts » Thu Jan 19, 2012 5:40 am
lumbercis wrote:Just fix it. If your steering wheel broke would you remove that too? :P
LOL a steering wheel is a necessity tho. Power steering isn't.
celigts
Postby celigts » Thu Jan 19, 2012 6:06 am
brutekiller787 wrote:pretty simple to do the outside stuff, complicated to make it work correctly. you actually need to cut off the seals inside the rack that keep fluid on one side or another in order to have a true manual rack. there was a write up on a miata forum i think, with pictures and everything. let me see if i can find it...
That is a good read for sure ! But definitely not for me ;) I'll keep everything there for now. But I really don't mind not having to struggle in parking lots and parallel parking. I just feel like an idiot when everyone else uses a finger to steer an I'm man handling the wheel like a mad man lmao
celigts
Postby sMARTINside » Thu Jan 19, 2012 8:31 am
Personnaly, I love the assistance of power steering. If I was in your shoes, I would repair it. It makes the car handle easily. My pickup doesn't have it and is a bitch to drive. I think that car that don't have it have a bigger ratio on the rack to make the steering turn easier. The ST185 doesn't have that many turns lock to lock, so I guess it will be hard as a rock to turn that wheel. My 2 cents... :|
sMARTINside
Postby MrDB » Thu Jan 19, 2012 11:00 am
said it before its fine until that accident and you cant turn the wheel fast enough! Ratios are all wrong and its way to heavy more than a stock manual rack...
MrDB
Postby Corey » Thu Jan 19, 2012 3:19 pm
Didn't the TTE cars keep their PS also?
Corey
Images: 49
Postby celigts » Fri Jan 20, 2012 6:32 am
Corey Darling wrote:Didn't the TTE cars keep their PS also?
Sounds like the smart thing to do. Would be a pain in the ass otherwise lol
celigts
Return to How To
