???BOV vac line??????
Postby Alltracghost » Thu Mar 29, 2012 10:26 pm
Does anyone know where to connect the bov vac line?
Alltracghost
Re: ???BOV vac line??????
Postby alltracst185 » Thu Mar 29, 2012 10:47 pm
Anywhere off of the intake manifold works :wink:
alltracst185
Postby Alltracghost » Thu Mar 29, 2012 11:00 pm
Really I heard from people tht its only one line that has to e sheared...!!!
Alltracghost
Postby Corey » Thu Mar 29, 2012 11:33 pm
I used to have mine t'd into the line running to the map sensor on the firewall just because it was easy to access.
Corey
Images: 49
Postby underscore » Fri Mar 30, 2012 12:15 am
^ pretty sure that's where I hooked mine in as well.
Postby Alltracghost » Sat Mar 31, 2012 6:15 am
Do u guys have a picture...? I just want to make sure I do this right...
Alltracghost
Postby Alltracghost » Sun Apr 01, 2012 2:23 am
Do anyone know exactly on which acume line cause there r many on the firewall...
Alltracghost
Postby Corey » Sun Apr 01, 2012 3:38 am
The Map sensor is the black cubeish box with a green label mounted on the firewall to the right of the intake manifold. The line hooks up to it from undernieth. Not to be confused with the AC idle up valve, which has a large screw/spring on it.
There is also a spare vacuum port on the back of the manifold you could use. It is capped from the factory with a rubber cap. You should be able to see it and reach it okay.
Corey
Images: 49
Postby Alltracghost » Sun Apr 01, 2012 8:40 pm
Got it thanks for the help sounds awesome!!!
Alltracghost
Return to How To
