How to disable check engine code 54 on ST205 ECU
Postby belanger33 » Sun Apr 08, 2012 9:59 pm
Hi,
I just did a gen 2 to gen 3 conversion on my ST185 RC 1991 GT4 and i am running across one and only check engine code....It is the code 54 which is for the intercooler pump error...I would liek to know what do people do to disable this check engine code since it limits your boost level quite considerably...
Thanks for the help!
GT-Four RC 1991 RHD
belanger33
Re: How to disable check engine code 54 on ST205 ECU
Postby l0ch0w » Wed Apr 11, 2012 12:27 am
run a pin from that connector to ground.
Andrew
1991 Red Alltrac
l0ch0w
Postby klue » Wed Apr 11, 2012 1:27 am
it needs a resistance not just gnd.
Used an mr2 ecu so i could get away from this issue but I believe its around a 1k resistance it needs to see
Postby underscore » Wed Apr 11, 2012 4:07 pm
If you have an RC can't you tie it into the existing pump? Or did you switch to a FMIC?
Postby phattyduck » Wed Apr 11, 2012 4:34 pm
Assuming you are using all the correct ST205 parts/wiring/relays but air-to-air intercooler: If the code is for the level sensor, you need to short the two pins on the (now unused?) level sensor connector. If its for the pump, 'replace' the pump with a resistor (1Kohm or similar should work).
We need more info on the setup to know for sure what you need to do.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby belanger33 » Wed Apr 11, 2012 7:50 pm
I have a RC so
I therefore have a water to air intercooler! The only code i get is 54 which is either level sensor on the intercooler which is plugged presently or its the pump
Connector.... I highly doubt my intercooler level is bad since it didnt change in a day and i hadnt the code54 before....
GT-Four RC 1991 RHD
belanger33
Postby esracing » Wed Apr 11, 2012 7:55 pm
just ground the win wire.that will turn the light out
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby underscore » Wed Apr 11, 2012 7:56 pm
check the intercooler level sensor by bridging the terminals with a paperclip, when I got my car the sensor itself was bad.
Postby esracing » Wed Apr 11, 2012 7:58 pm
the intecooler ecumenical is different so just ground it
2008 tundra blue
esracing
Postby CMS-GT4 » Wed Apr 11, 2012 7:59 pm
Posted in the wrong section, and there is a thread on this:
viewtopic.php?t=17368
Postby Texasnick » Mon Apr 23, 2012 8:10 pm
Keep in mind that level sensor is VERY picky.
You've got to blip the throttle with the cap open and fill it as full as it will go with the pump running and then sort of cram the cap back on.
If it's warm now and it gets significantly colder in winter you'll probably have to top it up then too. I think it was about 1/4" of fluid that made the difference between a 54 and no code for me.
There is also a procedure in the BGB on how to check if the sensor is working correctly.
Nick
Texasnick
Return to How To
