Where an how to install oil pressure gauge
Postby celigts » Sat Jul 14, 2012 4:37 am
So I can't find any good references about installing this. Bought I and it's a mechanical autometer phantom gauge. Cam with 2 canister regulator things an the gauge.
What I don't get is where the oil pressure sensor is on the car and how to fit this canister to it and t off it or anything!
Help me please. Need at.net help
3SGTE project motor very slow
celigts
Re: Where an how to install oil pressure gauge
Postby jaydog82 » Sat Jul 14, 2012 4:48 am
Pics please
jaydog82
Postby WarTowels » Sat Jul 14, 2012 4:53 am
I think if you unbolted the turbo from the manifold and lowered it a bit you'd be good.
EDIT: No clue what I was talking about here, I think i must have responded to the wrong thread forever ago.
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby tubasteve » Sat Jul 14, 2012 5:19 am
Spell check, had to re read a bunch.
Use the pressure sensor port on test of head.get a British pipe thread t-pipe if you want to keep your oil pressure switch?
Maybe?
-Jr
tubasteve
Postby celigts » Sat Jul 14, 2012 5:48 am
Wartowels what do you mean.?
I'll post pics of the product tomorrow. And what's a British pipe thread?
celigts
Postby tubasteve » Sat Jul 14, 2012 5:52 am
What Toyota used in their infinite wisdom.....when the rest of the world uses another.
tubasteve
Postby 4rsnduction » Sat Jul 14, 2012 6:35 am
celigts wrote:What I don't get is where the oil pressure sensor is on the car and how to fit this canister to it and t off it or anything!
Your stock oil pressure sensor is located on the side of the head, it makes sure the highest point of the oil circulation system is being monitored for pressure, you can purchase a T shaped brass fitting that has 1 male threaded end and 2 female ends and put it into this hole, allowing you to use the stock sensor aswel as your aftermarket sensor.
The other option is to purchase a sandwich plate, it would sit in between the oil filter and the silver cooling unit the oil filter screws onto....this sandwich plate has 2 holes in it for sensors, one for oil temp and the other for oil pressure....best thing is both the holes are the right thread size for gauges.
4rsnduction
Postby celigts » Thu Sep 20, 2012 3:17 pm
Could you get me a pic of the oil pressure sensor? I think I have the canister fitting and it doesn't send oil to the cab and just uses the signal from the stock sensor.
Make sense?
celigts
Return to How To
