Desperate!!! Idle rough and stalls out when cold! Help!
Re: Desperate!!! Idle rough and stalls out when cold! Help!
Postby Alltracghost » Mon Oct 21, 2013 5:25 pm
This harness that connects to the sensors is all beaten up... On one sensor connector the cable is almost cut completely... It's holding on by a wire thread or two... The other sensor has only one wire connected to it... The other wire it's not making contact seems like someone tried to solder it before... Any ideas where I can get this wire harnes or name or part number doesn't have any on it....
Alltracghost
Postby Alltracghost » Mon Oct 21, 2013 5:26 pm
Alltracghost
Postby Alltracghost » Mon Oct 21, 2013 5:27 pm
[IMG]
Alltracghost
Postby zedxfarin » Mon Oct 21, 2013 5:41 pm
I knew it looks like you found the problem my friend, I would try and find someone braking the same car for a harness but I am sure you will find one.
All the best from Zedx
YES I KNOW I HAVE NO SIGNATURE!!!
zedxfarin
Postby Alltracghost » Mon Oct 21, 2013 5:45 pm
Yeah I really hope this solves my problem I a predicate all your help bro... Thank you...
I will go check Toyota parts store luckily there is one nearby...
Alltracghost
Postby Alltracghost » Mon Oct 21, 2013 7:21 pm
Wow Toyota parts has no parts for my car hahaha!!!
Alltracghost
Postby Rick89GTS » Wed Oct 23, 2013 5:44 am
You may have to solder a new portion of wire in there. My wires were nice and crispy too.
Rick89GTS
Postby Alltracghost » Wed Oct 23, 2013 9:36 pm
Yeah that part I will do but when I asked for the sensors at the Toyota parts they said they didn't have them I even took pictures of the sensors and triple check the part number... Nothing appeared in their inventory...
Alltracghost
Return to How To
