HOW TO MAKE A SS BRAIDED OIL RETURN/FEED SETUP
Postby jaydog82 » Mon Oct 28, 2013 2:59 am
I am almost done building a ss braided oil feed/return line for my 88 st165 with a stock 1st gen 3sgte and stock ct26 turbo.
here is the main site for the parts http://shopping.kinugawaturbo.com/
http://shopping.kinugawaturbo.com/turbo ... eturn.aspx
http://shopping.kinugawaturbo.com/braid ... ght12.aspx
http://shopping.kinugawaturbo.com/braid ... t12-1.aspx
http://shopping.kinugawaturbo.com/adapt ... rab-3.aspx
http://shopping.kinugawaturbo.com/oildr ... v2mr2.aspx
http://www.ebay.com/itm/Turbo-Oil-Feed- ... 0c&vxp=mtr
this is the web site i used for the kit, then the -10 an 90 degree fitting and the oil drain pan adapter is needed. the only thing else i need to figure out is the oil feed fitting. I am going to measure the banjo fitting on the oil cooler and try to find a new replacement that has a -4an end on it. If that does not work i will adapt the oe banjo piece to -4an.
jaydog82
Re: HOW TO MAKE A SS BRAIDED OIL RETURN/FEED SETUP
Postby jaydog82 » Mon Oct 28, 2013 3:07 am
jaydog82
Postby jaydog82 » Mon Oct 28, 2013 3:46 am
Here are the first pics.
jaydog82
Postby underscore » Mon Oct 28, 2013 4:50 am
I bought the full kit off ebay except I think it was for some other engine that used a CT26. It has everything you listed and some other odds and ends but I was missing that M26 to 10AN adapter, thanks for posting that! IIRC that's a lot cheaper than the other "name brand" ones.
edit: their adjustable wastegate actuator is pretty slick too, I've never seen that before.
Postby jaydog82 » Mon Oct 28, 2013 5:13 am
Ya I was checking out their web site, cool stuff. Looks like good quality too. Fast shipping as well.
jaydog82
Postby klue » Mon Oct 28, 2013 10:52 pm
Very interested to see how this turns out, keep us posted.
Postby killemalltrac » Mon Oct 28, 2013 11:13 pm
Hope it works as well as it looks! Very curious to see the end result.
#80sMurderCar
killemalltrac
Images: 10
Postby polm » Tue Oct 29, 2013 1:21 pm
underscore wrote:edit: their adjustable wastegate actuator is pretty slick too, I've never seen that before.
Do not buy this crap!! I bought one and its complete garbage. The actuator arm is too short to reach the wastegate flapper! So I welded an extension but the I noticed the bracket mounts the wastegate about 2 inch lower than the original wastegate, meaning it'll hit the transmission and it won't fit where it's supposed to. Another thing is the actuator arm unscrews itself, which is really odd, it becomes loose by itself. So in the end I spent a couple extra hours trying to fit this thing and it wont fit in the end. I strongly advise you stay away from this part!!
polm
Postby Theman88b » Tue Oct 29, 2013 5:42 pm
I am in the process of doing this as well. I believe the return line is too short so you may have to have one made. KO Racing makes a fitting that screws into the block that adapts to a -3 or -4 an.
'88 Toyota Celica All Trac Turbo(Blue) 145k - Rebuilt and Bored 1mm over, big psi soon!!
'92 Ford Taurus SHO(White) 212k - Some mods but still my DD
Theman88b
Images: 3
Postby underscore » Tue Oct 29, 2013 6:27 pm
I believe that's what the last adapter posted is for, except it's a lot cheaper than I remember KO being.
Postby jaydog82 » Tue Oct 29, 2013 6:34 pm
Do you mean the feed line?
jaydog82
Postby Theman88b » Tue Oct 29, 2013 9:15 pm
The kit I bought came with 10'' return and feed lines. Having to use a 90 degree fitting on the pan and 45 degree off the turbo. Have you set yours up yet? Would like to see some pictures of it all finished. I also do not have the factory oil cooler anymore.
Theman88b
Images: 3
Postby klue » Wed Oct 30, 2013 1:02 am
KOracing sells a quality product, not to be compared with what is on this thread. Hence the price difference. Just look at the close up pic with that terrible machining on the fitting. The seat also looks very short to me
They also support the forum by being a sponsor, which is nice to get support back from the forum members :)
Postby jaydog82 » Thu Oct 31, 2013 7:24 pm
Last piece to the project, 4an brazed onto the m18 banjo for the oil feed line
jaydog82
Postby jaydog82 » Sun Nov 03, 2013 9:29 pm
So this project was not as easy as I had hoped lol. The oil return line was 2 inches too short. I had an m to FM piece made to make it work.
jaydog82
Return to How To
