HOW TO MAKE A SS BRAIDED OIL RETURN/FEED SETUP
Re: HOW TO MAKE A SS BRAIDED OIL RETURN/FEED SETUP
Postby jaydog82 » Sun Nov 03, 2013 9:30 pm
Pics
jaydog82
Postby jaydog82 » Sun Nov 03, 2013 9:31 pm
More
jaydog82
Postby MWP » Mon Nov 04, 2013 2:48 pm
Be careful... quite a few people have had the feed pipe on these crack :(
There are better versions around that have a reinforced feed pipe.
Postby jaydog82 » Mon Nov 04, 2013 7:27 pm
How the heck do they brake that? Mine has plenty of hose on it and no tension.
jaydog82
Postby klue » Mon Nov 04, 2013 9:56 pm
jaydog82 wrote:How the heck do they brake that? Mine has plenty of hose on it and no tension.
As I told you in the PM, the vibration, poor material quality, thin flange, thin wall tubing, not to mention the distance from the fitting to the flange will put a lot of leverage on the weld area.
Postby underscore » Mon Nov 04, 2013 10:30 pm
If you know someone who can weld decently just get them to beef it up a little and you're good to go.
Postby CSAlltrac » Tue Nov 05, 2013 3:58 am
I'm just curious, what's wrong with the hard lines Toyota designed. As long as there are no kinks or cracks it doesn't get much more reliable.
Postby underscore » Tue Nov 05, 2013 4:11 am
Working with them sucks?
Postby jaydog82 » Tue Nov 05, 2013 4:33 am
I messed mine up and my 90 degree rubber boot went bad
jaydog82
Postby Theman88b » Wed Nov 13, 2013 3:16 am
Like I said mine is a bit custom but just finished the other day:
800
The fitting from KO Racing is -12 an so had to adapt it down a bit...
799
Had to use a 90 degree on the pan and 45 degree on the flange to get the 10'' drain line to fit. Feed line is right from the block.
798
How do you think the line will hold up to heat? Mine is close to the exhaust, going to heat wrap that area. Seems the inside of the line is poly, hope it doesn't melt.
'88 Toyota Celica All-Trac Turbo(Blue) 145k - Race car!!!
'92 Ford Taurus SHO(White) 212k - Intake and exhaust, needs a clutch at the moment
'98 Jeep Cherokee - Current DD, 33" tires and 2 light bars :rofl:
Theman88b
Images: 3
Postby MWP » Tue Nov 26, 2013 2:05 pm
Its -12 for a very good reason.
If you make the return too small, oil pressure builds up in the turbo and seeps past the seals.
Postby Theman88b » Tue Dec 03, 2013 12:26 am
-10 an is fine in my opinion. Not a big deal that it is -12 an though, I should've bought a 90 degree -12 an instead of adapting it to -10 an first. Would save room and maybe the line would reach the turbo. Oh well....lol
Theman88b
Images: 3
Return to How To
