ST165 Shift Cable Replacement
Postby runt9 » Sun Feb 09, 2014 3:07 am
Hello all, I will be doing a replacement of the shift cables on my ST165 tomorrow and I was looking around and didn't see any how-tos on anything but the ST185. I'm sure the procedure is just about the same, but before I dove in and started pulling half my car apart, I wanted to make sure there was nothing to be aware of that would be different between the two cars.
Also, in that procedure, they talk about removing the glove box and all the stuff over there to get at the cables, is that necessary? I just want to make sure I do this right, obviously, so I thought I'd check with you all first. Thanks.
Return to How To
