[How to] Remove gauge cluster and repair faulty tach
Re: [How to] Remove gauge cluster and repair faulty tach
Postby Corey » Mon Apr 20, 2015 12:58 am
Removed my rev counter today. This is what I found. New caps from digikey are on their way. I'm also replacing the bulbs in the cluster and hvac while I have it apart.
26 year old revcounter with 157K km on the clock.
Note the damaged capacitor on the right is missing the same markings as the undamaged one on the left. I don't see any branding, specs or polarity markings on it. The only thing they have in common with each other are the blue wrap and the orange 904E marking (not sure what that indicates).
I'm going to install the new capacitors using Nubkin's photo as a reference for the polarity since one of my caps has no markings.
Corey
Images: 50
Postby yyonline » Mon Apr 20, 2015 3:02 am
The triangle logo on the one capacitor is a very old Panasonic logo. I also see the marking KG which is a discontinued series of Panasonic capacitors.
904E is a date/lot code. Older Panasonic caps used red lettering for the date codes. I'm not quite sure how to decipher that as it doesn't seem to follow the same system that modern Panasonic capacitors use.
yyonline
Postby Corey » Thu Apr 23, 2015 1:44 am
Replaced both capacitors this evening, went for a test drive, seems to be working properly again.
I managed to replace them without removing the gauge dial/needle - just need to be careful not to get oily fingers on the gauge face because it will leave marks which can be tough to clean off.
Thank you Nubkins for the great writeup and to yyonline for the digikey link for the proper capacitors.
Corey
Images: 50
Postby TheNubkins » Thu Apr 23, 2015 3:34 am
So glad to hear the repair worked out for you! And what a good idea keeping the gauge face in place! lol. Nicely done!
The Nubkins
-2001 VW Golf TDI
TheNubkins
Postby Sifu » Thu Apr 23, 2015 1:54 pm
This thread needs to be stickied.
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Brad_91 » Thu May 19, 2016 5:01 pm
Thanks for the write up!
I just swapped out my whole tachometer dial with a functioning one instead of messing with the capacitors in the original. I can attempt to fix my spare cluster now as a project..
Would have taken a lot longer to pull the cluster out the first time without this easy step by step! :notworthy:
Brad
1992 Celica GT-Four
~65'000km,
Mods: Turbo-back 3" Exhaust, 17x8 Versus Turismo Rims, Black Rally Armor Mud Flaps, turbo timer, manual boost controller, Whiteline rear swaybar!
Brad_91
Return to How To
