TFFR Trouble
TFFR Trouble
Postby celicasilfee » Tue Apr 15, 2014 2:06 pm
Hey guys. I recently "installed" my Wolfkatz TFFR & ran into a couple of issues.
First things first, I have a ST185 with a 2nd gen jdm 3sgte in it. I have a moderate amount of experience installing things since I read on here for days & my car hasn't seen the inside of a shop for anything. I had previously removed my stock rail/injectors with a bored rail & 550cc's, then realized that it wasn't enough fuel for the rest of my setup, so when I got some money, I bought the Wolfkatz TFFR (straight from Wolfkatz) and some Precision 880cc top feed injectors with the Toyota plug & play clips from KO Racing. I installed everything properly (as far as I know) from what I've done before and reading the instructions from Wolfkatz.
First issue: with the injectors in the rail & the rail bolted up, the injectors don't reach the head. There's probably 1/8" left before they even begin to seat in the head. Anyone else ever have this issue? I figured I could just mod the brackets that hold the rail to the head, but considering this is from Wolfkatz, I assume it's more-likely something I did improperly. How did you guys get the injectors to seat in both the rail and the head? I searched, but couldn't find a write-up of a TFFR install.
Second issue: I can't get the injectors to clip into the harness, even with the Toyota plug & play clips. There's a purple rubber piece in the section where it clips in (injector side), but I can't get it to stay even with that removed. I'm sure this is something simple I'm just being dumb about, but for the life of me, I couldn't figure it out.
So there we have it. That's where I'm at. Any help would be insanely appreciated.
'96 GT (money pit jr)
For show
'90 GT4 RC (money pit sr)
For go
celicasilfee
Return to How To
