ST185, SWAP ECU and Code error 54
Re: ST185, SWAP ECU and Code error 54
Postby Locker » Thu Nov 05, 2015 1:27 pm
Gibs wrote:
Locker wrote:I'm not sure why you opened up the ECU
To do the mod inside the ECU. (I have no electricity to solder in my garage).
So I took the ground of the ECU.
I believe your thinking too much. This is a SUPER easy fix for the 185RC.
All you need to do is snip the INT wire. then ground the wire from the ECU side of the harness.
90 ST185
Locker
Postby Gibs » Thu Nov 05, 2015 5:18 pm
hehe thanks for your help. :notworthy:
I think we never think too much. :roll:
Since the beginning I'm talking about the CS mod and you are talking about the RC.
I did the conversion 10 years ago, and at the time a friend did it before me and his fix was to remove the check engine bulb (in his car) :)
So now, I want to fix it properly.
I admit, I did not snip the INT wire. I just put it to the GND. The reason is that it my intercooler is not managed by the ECU anymore : when I start the car it runs until I stop the car.
I also own a Japanese ECU (the RC one), and from what I remember It doesn't report the code 54 without any tricks. The reason I don't use the RC one is because I think it is better to run with an european ECU (no need to raise the octane %).
So even if the car is running correctly there are still pinouts that doesn't match.
Also the 26 & 16 pins harness is from the CS, while the 22 pins is from the car. Maybe there's something to do with the WIN pin...
Can you confirm that my INT pin is this one ?
Gibs
Postby underscore » Thu Nov 05, 2015 7:23 pm
If you want to confirm the pinout I believe Toyota usually labels the pins on the PCB inside the ECU case.
Postby Locker » Fri Nov 06, 2015 1:05 am
Gibs wrote:Can you confirm that my INT pin is this one ?
from what I can tell that is the right PIN. it was a pink wire in my car with a stripe I believe.....
I'm no electrical guru. I was shown the pin out diagram told to cut the INT wire and ground it and boom no light and the car no longer ran in limp mode.
90 ST185
Locker
Postby Gibs » Fri Nov 06, 2015 4:54 pm
Locker wrote:I've grounded the WIN pin.... that's why I'm confused... I must be missing something. I read somewhere about wiring 2 resistors in parallel at the pump but I thought grounding the WIN pin eliminated the need for that?
Ok, in the thread you have opened you're also talking about the WIN wire.
Did you kept the WIN pin grounded also ? Thanks
Gibs
Return to How To
