How to remove breather tube from valve cover
Postby CELL_PROTOTYPE_X » Fri Apr 28, 2017 9:49 pm
I want to swap this out for an AN fitting. Can anyone advise on how to remove it? (top right of pic) Is this press in? Any info would be helpful. Thank you!
https://www.dropbox.com/s/j4h61dtjucr1zmi/IMG_3950.JPG?dl=0
CELL_PROTOTYPE_X
Re: How to remove breather tube from valve cover
Postby GT4_DRED » Sat Apr 29, 2017 3:56 am
I clamped the tube in a vise and rotated the vc left/right while pulling back on it. I replaced it with the racerx piece http://racerxfabrication.com/mr2-celica/misc/valve-cover-an-fittings
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby CELL_PROTOTYPE_X » Sat Apr 29, 2017 11:09 am
Thanks for the info! Did you also replace the pcv valve? I have a gen3 motor and am wondering if I should keep it or not. I see racerx also has a press in replacement for that as well.
CELL_PROTOTYPE_X
Postby GT4_DRED » Sun Apr 30, 2017 1:24 am
CELL_PROTOTYPE_X wrote:Thanks for the info! Did you also replace the pcv valve? I have a gen3 motor and am wondering if I should keep it or not. I see racerx also has a press in replacement for that as well.
I left that one stock..
'91 MR2
GT4_DRED
Return to How To
