[How to] Install an aftermarket boost gauge
Postby Gary » Wed Jun 01, 2005 11:59 am
What you need:
1) A mechanical boost gauge.
I'm using an Auto Meter® Ultra-Lite 2-1/16" (# 4301) comes with 6ft nylon tubing and fittings.
2) 5/16" (inner diameter) rubber tube
(at least 4-inch long, mine is 1 ft.)
3) 2 Hose clamps for the rubber tube above.
4) Adapter (from any hard wear store) to connect the rubber tube
to the NPT fitting (provided with the gauge)
5) Teflon sealing tape or sealing compound.
Schematic:
What to do:
1) Locate the vacuum/boost source behind the throttle body.
2) Remove the rubber cap. Keep it some place safe.
You might need it in the future.
3) Connect the rubber tube. Use the clamp to secure it.
4) Connect the other end of the rubber tube to the nylon tubing
(provided with the gauge). Always use Teflon sealing tape.
5) Route the nylon tube trough the fire wall.
I route it through the driver side wheel well.
6) Connect the nylon tube to the meter following the gauge instruction.
Start the engine. Check for leak. Gauge should read about 17-21 in.Hg at idle.
7) Connect the gauge light to the power source. I parallel it to the ash tray bulb.
The light will turn on with other interior lights. It can also be dimmed with the dimmer.
8 ) Drive the car and check the boost. Now, you will realize how slow the stock boost gauge is!
Stock boost is around 7-11 psi.
Disclaimer: Do it at your own risk. I'm not responsible for any damages caused by following this instruction.
It is your responsibility to make sure that materials are fire proof and
can withstand heat in the engine compartment.
Always follow manufacturer's instructions.
93 ST185
Gary
Postby QIK_GT4 » Thu Jun 02, 2005 2:52 am
would that be the same source i would use for my BOV vacume?
The Car:Black JDM 1990 ST185
The Mods: Whiteline Rear-sway-bar, K&N Panel, 3" Dump, HKS BOV, 2" Boost Gauge, Garret TMIC, TWM Short Shifter, Mirror Tints
QIK_GT4
Postby Gary » Thu Jun 02, 2005 5:31 pm
QIK_GT4 wrote:would that be the same source i would use for my BOV vacume?
Yes.
93 ST185
Gary
Postby QIK_GT4 » Thu Jun 02, 2005 11:16 pm
great all i need now is a BOV lol
QIK_GT4
Postby AlltracAvenger » Fri Jun 03, 2005 3:01 am
Quick question... I heard from other sources as well that you can route it through the wheel well. Any disadvantages to this setup than via the firewall, and how exactly would it be done?
'88 ST165 #2914- Sold 12/21/06 :(
'88 ST165 #3784- Bought 05/08/15 :D
'05 Corolla XRS- Daily Driver
AlltracAvenger
Postby toayoztan » Fri Jun 03, 2005 12:57 pm
AlltracAvenger wrote:Quick question... I heard from other sources as well that you can route it through the wheel well. Any disadvantages to this setup than via the firewall, and how exactly would it be done?
It's just easier to go through the firewall than the wheel well.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby Rick89GTS » Fri Aug 12, 2005 2:19 am
Excellent write-up Gary :)
Should be a sticky.
Rick89GTS
Postby RIalltrac » Fri Aug 12, 2005 11:14 am
You need to remove the liner on the inside of the wheel well, then you'll see the boots that wiring goes through. You could use those same boots to get the vacuum source in/out. I did the firewall method, but plan on changing it to the wheel well option, just cleaner overall imo.
Chris - 90 ST185
RIalltrac
Images: 2
Postby QIK_GT4 » Mon Sep 12, 2005 9:55 am
ok i installed my boost gauge just the other day and why the hell is it reading at 25 - 30 in.hg?
look i got a pic..
is my car stuffed or could gauge be inaccurate?
QIK_GT4
Postby Aracheon » Tue Sep 13, 2005 6:52 pm
How much different is the install procedure for an electronic boost gauge, like a GReddy or a Defi?
Chris
2009 STi
2008 Superduke
2009 DR-Z400S
2004 KLX 125
Aracheon
Postby Aus_GT4 » Tue Oct 04, 2005 4:31 am
Is this essentially the same write up for an st185?
Aus_GT4
Postby toayoztan » Sat Aug 19, 2006 6:59 pm
Aus_GT4 wrote:Is this essentially the same write up for an st185?
The car used in the pictures is an ST185. In any case, this write up can be used for both the 165 and 185.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby //Zee-Roh// » Sun Aug 20, 2006 1:37 am
Both of my ports are being used....what's going on?
'88 All-trac ST165
-Joel
//Zee-Roh//
Postby Gary » Sun Aug 20, 2006 2:46 am
For people without an empty port, you can just use a "T" on any vacuum line from the intake manifold.
93 ST185
Gary
Postby //Zee-Roh// » Sun Aug 20, 2006 6:22 am
But it's so cramped down there....*sigh* man that's gonna take a while LOL
'88 All-trac ST165
-Joel
//Zee-Roh//
Return to How To
