[How to] Install an aftermarket boost gauge
Postby airpak » Sun Jun 10, 2007 12:48 am
whered you guys find the rubber tubing and adapter?
airpak
Postby Gary » Sun Jun 10, 2007 1:02 am
Rubber hose and 5/8" brass adapter from ACE hardware.
Nylon tubing and connectors supplied with the gauge.
You can get them from Autozone too.
93 ST185
Gary
Postby airpak » Sun Jun 10, 2007 4:18 am
where do all the canadians go for their parts like this?
airpak
Postby snakeeater » Fri Jan 30, 2009 3:07 am
Canadian Tire
snakeeater
Postby snakeeater » Fri Jan 30, 2009 5:25 pm
tw2 wrote:Yes you can T it off for your BOV vacuum.
Gary wrote:For people without an empty port, you can just use a "T" on any vacuum line from the intake manifold.
Not that this is important at all but I recently found that my boost gauge had been T'd into the line going to the I think AC idle up valve. This line had a filter or check valve or something in it which affected vacuum reading and sometimes boost. I changed it to the way described here.
This thing here from
This port here. You can see all the other ports on the manifold in this picture. There is a largish one under the last "hole" on the TVIS.
Could I T It before That white filter thing or one the line next to it?? Would I get as accurate readings compared to if i Used the "proper" port??
snakeeater
Postby Gary » Fri Jan 30, 2009 5:29 pm
snakeeater wrote:Could I T It before That white filter thing or one the line next to it?? Would I get as accurate readings compared to if i Used the "proper" port??
Yes, you will get the same reading.
That plastic thingy is a "jet" or one way valve.
If you connect the gauge to the line before it, you will read both vacuum and boost correctly.
93 ST185
Gary
Postby SleepingTurbo » Sat Aug 15, 2009 5:36 pm
is there a way to route the vaccuum lines into the radio space? my car doesnt have a radio, and i was gonna use that space for my gauges.
May be moving on from the All Trac world.
SleepingTurbo
Postby Tarmac_St165 » Mon Nov 16, 2009 12:36 am
On the 165 there's 2 fittings in the intake I wasn't sure witch one to use. One looks like it went to the brake booster? So I used the other one, I just pulled the existing line off and connecting my new hose. Should I block off the old hose will that give me a vaccume leak if I leave it there? I have it like this for a few days it seems fine, My gauge reads 15 vac when its cold and about 19 or 20 when warmed up.
Tarmac_St165
Postby Gary » Mon Nov 16, 2009 6:20 am
SleepingTurbo wrote:is there a way to route the vaccuum lines into the radio space? my car doesnt have a radio, and i was gonna use that space for my gauges.
Sure, if you have the nylon tube that is long enough.
93 ST185
Gary
Postby Gary » Mon Nov 16, 2009 6:21 am
Tarmac_St165 wrote:On the 165 there's 2 fittings in the intake I wasn't sure witch one to use. One looks like it went to the brake booster? So I used the other one, I just pulled the existing line off and connecting my new hose. Should I block off the old hose will that give me a vaccume leak if I leave it there? I have it like this for a few days it seems fine, My gauge reads 15 vac when its cold and about 19 or 20 when warmed up.
I would use a T-fitting.
93 ST185
Gary
Re: [How to] Install an aftermarket boost gauge
Postby 1BADGT4 » Sat May 22, 2010 7:39 am
Guys, I have an autometer installed but the tube broke off inside the nut and adaptor. No biggy right? I cut the flattened end off, and tried to stick the ferrule (see pg1) back on the tube. ... ... Not happening. I read this thread couple more times and can't find anything about sticking hte tube through the ferrule. Is that dang thing a one time use, or did I miss something on this thread?
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
Postby Gary » Sat May 22, 2010 1:13 pm
Most brass ferrules will deform and cannot be reused when it is overtightened. You can get a new one from a hardware store or Autozone.
93 ST185
Gary
Postby all(trac)way » Sat May 29, 2010 7:11 pm
I got a prosport electric gauge did any one figure a good place to run the power cords to?
John
recruiting for celica tech come join a private forum with us i promise we dont bite and we wont sell out
celicatech.com
all(trac)way
Postby monkninja » Tue Mar 29, 2011 9:51 pm
Excellent write up! Thank you everyone who contributed and Gary!!
Kyle
1990 AllTrac
1999 Kawasaki ZX9R (Usual daily driver)
2003 Matrix Xrs (Wife's car)
monkninja
Postby aus jd 2703 » Tue Mar 29, 2011 11:36 pm
i got a question, can you t into the map sensor and if not why?
great write up but
aus jd 2703
Return to How To
