North American ST205 owners
Postby Quakefire » Thu Nov 26, 2009 5:53 pm
Pictures after i'm done removing the tint from the rear window. Its not going well....
1994 Toyota Celica GT-Four Daily Driver
Quakefire
Postby GTFOURST205guy » Thu Nov 26, 2009 9:10 pm
Quakefire wrote:Pictures after i'm done removing the tint from the rear window. Its not going well....
Ya i'd like to take the tint off mine but i decided not to get into that kind of mess so i deal with it for now.
'94 GT-FOUR ST205
GTFOURST205guy
Postby Quakefire » Fri Nov 27, 2009 4:43 am
The tint has lots of long bubbles in it that were completely obscuring my view through the back. After two hours of scrapping i've got about a fifth of the tint off, tomorrow i'll try steaming it, or using a heat gun or something
Quakefire
Postby GTFOURST205guy » Fri Nov 27, 2009 4:48 pm
Quakefire wrote:The tint has lots of long bubbles in it that were completely obscuring my view through the back. After two hours of scrapping i've got about a fifth of the tint off, tomorrow i'll try steaming it, or using a heat gun or something
oh ya, I would have taken mine off if it had bubbles but lucky for me it doesn't :)
'94 GT-FOUR ST205
GTFOURST205guy
Postby Quakefire » Thu Dec 03, 2009 5:19 am
4 hours, a bottle of straight ammonia, extra fine steel wool, and numerous razor blades, and I can finally see out of my back window. And I only broke 4 defrost lines!
Quakefire
Postby GTFOURST205guy » Thu Dec 03, 2009 5:43 am
PICS!
'94 GT-FOUR ST205
GTFOURST205guy
Postby tintman22 » Fri Dec 04, 2009 4:32 pm
Dont use a scraper you will distroy your defrost lines. Use a heat gun and heat up an area ( preety hot ) about 8" square a slowly peel the tint of. It is alot of work. After you get all the tint off you will need windex and a garbage bag. on the outside of the window cut the garbage bag to the size of the inside of the window. Spray lots windex on the glue and cover it up with the garbege bag ( prevents the windex from evaperating) let is sit for about 1 hour. Peel back the garbage bag about 10" at a time and wipe the glue of with paper towel. If there is little bits of glue left over you can use the windex and some fine steel wool.
1990 Toyota Celica GT4 (write off )
1992 Toyota Celica GT4
1994 Toyota Celica GT4 Sold
1993 Toyota Celica GT4 Sold
"Power is nothing without control"
tintman22
Postby schmooot » Fri Dec 04, 2009 7:20 pm
does anyone else have a plastic shield fitted to the inside of the rear window. I'm torn on whether or not I like it
schmooot
Postby GTFOURST205guy » Fri Dec 04, 2009 7:29 pm
schmooot wrote:does anyone else have a plastic shield fitted to the inside of the rear window. I'm torn on whether or not I like it
pics? if it says toyota then i'd love it.
'94 GT-FOUR ST205
GTFOURST205guy
Postby Quakefire » Sat Dec 05, 2009 1:36 am
Part of the problem with the tint is that the layers of the tint had all separated, The heat gun and windex works great when all pieces of the tint are still together, your just left with the glue. Mine still had the tint layer as well. The ammonia eats all of that stuff, so I sprayed the straight ammonia onto the extra fine steel wool and rubbed, it took a few rolls of wool as they do clog up, but thats what worked best in this case (its also 20 below here so the heat gun is a scary idea)
The broken defrost wires can be fixed easy enough with a cheap kit.
Pics when I can
Quakefire
Postby schmooot » Sat Dec 05, 2009 7:31 pm
It says CELICA on it, looks like lexan or something, almost like rear window louvers, it fits on the inside of the hatch window and is attched with little brackets and screws....makes it kind of hard to see out the back if you ask me
schmooot
Postby GTFOURST205guy » Sat Dec 05, 2009 7:39 pm
schmooot wrote:Image
ya i can imagine, well actually i don't need to, my tint is so dark i pretty much can't see out the back. thats weird though i've never seen anything like that.
'94 GT-FOUR ST205
GTFOURST205guy
Re: North American ST205 owners
Postby Insanity-74 » Wed Mar 10, 2010 6:40 am
Dont know if he has posted on here or not, but a Guy has just joined the GT4OC who has an Real ST205 in New York, LHD imported from Italy, all legal....so it is possible. Nice looking car too.
Insanity-74
Postby mike325ci » Thu Mar 11, 2010 3:19 am
Insanity-74 wrote:Dont know if he has posted on here or not, but a Guy has just joined the GT4OC who has an Real ST205 in New York, LHD imported from Italy, all legal....so it is possible. Nice looking car too.
Yeah, I just saw that... And I can't believe he's my neighbor (well, within an hour's distance)!
NYC, NY, USA
mike325ci
Postby Domspun » Fri Mar 12, 2010 12:43 am
Not legal to an american citizen, he must be a foreigner.
Domspun
Return to GT Four Chat
