18x8 rims
18x8 rims
Postby ianpen » Sat Apr 10, 2010 9:25 pm
hi , im thinking of buying a set of rims . the size is 5x100 18x8 offset +30 .with 225/40 R18 tires. im just wondering if it's gonna rub on my fender well when turning , my car is a 1990 gt4 narrow body. is this the right offset for my car for 18" rims. have a nice day guys.
ianpen
Re: 18x8 rims
Postby alltracst185 » Sun Apr 11, 2010 2:27 am
You will have to roll the fender lips for sure, maybe even pull the rear a bit. The outcome will be 8)
alltracst185
Re: 18x8 rims
Postby Meurz » Sun Apr 11, 2010 5:39 pm
I think that setup will be too wide for a narrowbody. Talk to Corey (Darling) as iirc he also had fitment probs with his Crono's on his narrowbody?
Turbocelica.nl
Meurz
Re: 18x8 rims
Postby masco » Mon Apr 12, 2010 4:46 pm
We're going to be mounting 16x8 et38 on a narrowbody soon. I'll let you know how that turns out. The car is on Tein SS.
1990 Turbo4wd - 1990 Corolla GT-S - 2002 RX300
masco
Re: 18x8 rims
Postby ianpen » Tue Jun 01, 2010 4:40 pm
i just found out that the 18x8 with a +30 offset wont fit, even rolling the fenders. (on a narrow body style). im trying a 18x 7 rims . ill see if it works,
ianpen
Re: 18x8 rims
Postby Gary ST165 » Tue Jun 01, 2010 9:49 pm
ianpen wrote:i just found out that the 18x8 with a +30 offset wont fit, even rolling the fenders. (on a narrow body style). im trying a 18x 7 rims . ill see if it works,
check out this reference thread: viewtopic.php?f=8&t=1327
ST165 turbo 4WD
Gary ST165
Re: 18x8 rims
Postby jonnyboygt4 » Tue Jun 22, 2010 12:14 pm
ive got a set of 17x7 w. 225 45r17 tires on a narrow body and they rub with the fenders rolled also.only in the back tho when hitting a bump in the road..not sure of my offset tho... and im running 38mm wheel spacers in the rear..
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Re: 18x8 rims
Postby tw2 » Sun Jun 27, 2010 2:10 am
I have 17x7 38mm offset and 215/40/r17 rub on stock narrow body fenders but are fine when unprofessionally rolled. Car is not excessively low.
Thomas, JDM 90 185, 06 350z
tw2
Re: 18x8 rims
Postby Rallly » Mon Feb 01, 2016 2:44 pm
What about 18x7.5 42 offset on a widebody? Will that fit?
Rallly
Re: 18x8 rims
Postby Awesome-Trac » Mon Feb 01, 2016 4:07 pm
I'm running 18x8 42 offset which required fender folding and spacers in the rear
•Daniel
Awesome-Trac
Re: 18x8 rims
Postby Rallly » Mon Feb 01, 2016 5:15 pm
Awesome-Trac wrote:I'm running 18x8 42 offset which required fender folding and spacers in the rear
Is that a narrow body or wide?
Rallly
Re: 18x8 rims
Postby Awesome-Trac » Mon Feb 01, 2016 7:59 pm
On a ST165 which I guess is wide body and a st184 wide body
•Daniel
Awesome-Trac
Re: 18x8 rims
Postby GT4_DRED » Mon Feb 01, 2016 8:35 pm
I'm running 18x8.5 et42 with 225/40/18 in the rear (rolled/massaged) with 15mm spacers and 215/40/18 up front with no spacers. I honestly think 235s can fit all four corners on a ST165 with the right offset. HTH..
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Re: 18x8 rims
Postby Rallly » Mon Feb 01, 2016 9:00 pm
Sorry I should have mentioned my car is a 91 ST185 widebody AllTrac. Will 18x7.5 with 42offset fit?
Rallly
Return to GT Four Chat
