ST205 Part Numbers
ST205 Part Numbers
Postby Insanity-74 » Tue Jul 06, 2010 6:27 pm
You might find the odd useful part number here
alternator
cam & timing gear
charge cooler system
clutch
clutch line
clutch line
clutch master cylinder
clutch pedal
clutch slave
cooling system
cylinder head gaskets
Distributer
egr
engine block
engine block internals
engine cooling system
engine mounts
oil cooler
fuel pump
gear box speed sensor
gear selector cables
gear selector
gear stick
gear housing
gearbox housing 2
gearbox internals
gearbox oil cooler
gearbox oil pump
ignition leads
ignition leads
injection system
inlet/airbox
manifold WRC
manifold non WRC
oil pump sump gear
prop shaft
radiator
Will add more when I can :twisted:
Insanity-74
Re: ST205 Part Numbers
Postby Texasnick » Wed Jan 11, 2012 4:32 pm
Pictures saved.....definitely useful thanks man!
Nick
Texasnick
Postby ALLensTRAC » Wed Jan 11, 2012 6:56 pm
Awesome info thanks! If I may suggest a picture layout with part numbers for the rear brakes on the 205. I would like to try and source caliper rebuild kits and pads,shims,fits,rotors new. Thanks again,
Allen
Allen
ALLensTRAC
Postby aus jd 2703 » Wed Jan 11, 2012 9:09 pm
I have been told there are early and late model brakes so u have to be specific
aus jd 2703
Return to GT Four Chat
