CMS-GT4":17viuf77 said:Info on our final drive
http://gtfour.supras.org.nz/428ratio.htm
Slight explanation of final drive.
http://newcarbuyingguide.com/index.php/ ... event=view
Think of it as the final gear in a car before the drive wheels. By changing this gear it effects all the other gears since the energy goes through it last. When you hear of a mustang with a gear, it means they have changed their overall ratio for better acceleration. This tends to be a cheaper solution for decent speed gains. The rwd cars have theirs in the rear dif, but the alltrac houses its in the gearbox before the power split. This also makes it a harder item to change in the car.
