185 with 205 rear knuckles
Postby Turtle » Thu Jan 20, 2011 1:41 pm
I have a 185 and have been going through wheel bearings...I found a pair of rear & front 205 knuckles on this forum. I installed the rears the other day because another wheel bearing went out on me. here is my problem...when i try and put the rotor on, there is a lip on the hub keeping the rotor from sitting flush against the hub, its close but the rotor rubs against the caliper. I looked at both front and rear knuckles and all 4 of these have the lip on them which is not letting the rotor go on all the way. I tried torquing down just the rotor with lug nuts thinking it would slip over, but it didn't work. Do i need 205 rotors to make this work? Is it normal for them to have the lip there? I was thinking about just grinding it down, but i would rather get new rotors if i have to use the 205's ...any input would be greatly appreciate. thanks
Turtle
Re: 185 with 205 rear knuckles
Postby DeeCee » Sun Jan 23, 2011 11:17 pm
i think i know what you are talking about. st185 hub spigot is 54.1mm and st205/215 hub spigot is 55mm.
that means the centre bore of the disc is 54.1mm for st185 and 55mm for st205 and 215.
options. bore out the disc to 55mm on lathe, change hub from st205 to st185, lathe 55mm hub spigot down to 54.1mm
you can't put 185 discs on st205/215 hubs
GT Four Adovansu "I want to enjoy the powerful and nimble agility behavior."
Elephant: http://www.alltrac.net/phpBB2/viewtopic.php?t=26687
DeeCee
Postby Turtle » Mon Jan 24, 2011 12:06 pm
Thank you for that info. I have a st185 ...my 185 knuckle/hub is shot so i want to use the 205's(since i already have them)....can i just get 205 rotors and call it good? or would they interfere with the caliper? just feeling out my options for now. Thanks again
Turtle
Postby Meurz » Mon Jan 24, 2011 9:03 pm
Won't fit - stock 185 discs are 288x10 mm solid items, the ST205 discs are 315x16 mm and ventilated. Probably a different offset as well. You can put on the entire rear brake assy of the 205 though, good upgrade.
Turbocelica.nl
Meurz
Postby aus jd 2703 » Mon Jan 24, 2011 10:06 pm
sorry to hijack, but aren't rear brake upgrades a waste since the proportioning valve limits rear brake pressures thus limiting the affect a rear brake up grade will have? im curious as this has always bugged me :shrug:
aus jd 2703
Return to GT Four Chat
