Alternator bracket solution?
Postby IStalkgt4s » Thu Feb 03, 2011 7:21 am
recently i swapped my st165, i did a 3rd gen head on a 2nd gen block...the swap is in the car, but the problem i have run into is that the 2nd gen alternator bracket doesnt work... and i cant seem to find a 3rd gen bracket... any suggestions?
1990 st185 -Jayne- (Project)
1988 st165 -Susan- Daily Driver
2008 Tacoma -Maria- PreRunner
IStalkgt4s
Re: Alternator bracket solution?
Postby MrDB » Thu Feb 03, 2011 7:23 am
Do you have aircon if not move alternator down to where aicon pump should be and you can make a very simple bracket to hold it. makes doing oit filter easier too..
MrDB
Postby IStalkgt4s » Thu Feb 03, 2011 8:07 am
no aircon.... i will have to give that a try... thanks!!!!!!
IStalkgt4s
Postby MrDB » Fri Feb 04, 2011 7:52 am
opens up a load of space and move weight lower... I have a pick of it somewhere.... will dig it out...
MrDB
Postby MrDB » Fri Feb 04, 2011 9:41 am
mrbarry on th gt4oc posted this as his design.
MrDB
Return to GT Four Chat
