Missing Fuel Pump Fuse / Relay?!
Postby Angrysquirel » Thu Feb 17, 2011 4:27 pm
Hello,
There has been something that has been driving me nuts about the fuse box in the engine bay of my 93 ST185.
Shortly after I bought it, I went through and examined the finer parts and internals for weak spots or things that would need attention. I found in the fuse box under the marking for "Fuel Pump" the female connector for the fuse / relay was all burnt and melted!!
This doesnt seem to effect operation at all though.
Is the fuel pump now directly supplied power at all times? How would I verify this?
Thanks all!
"As a matter of deductive logic, Norman... we die down here"
Angrysquirel
Re: Missing Fuel Pump Fuse / Relay?!
Postby McKenzieJr18 » Sun Feb 20, 2011 3:12 am
turn on the ignition and you will hear the pump run for a coupe sec then it should turn off if not its wired to run constantly
92 alltrac 3rd gen 3s
McKenzieJr18
Postby Angrysquirel » Sun May 15, 2011 3:39 pm
Thanks - Relay is there, was just wired outside of the fuse box :)
THREAD CLOSED - THX
Angrysquirel
Return to GT Four Chat
