St 165 LSD
St 165 LSD
Postby bmt » Sat Mar 05, 2011 9:51 am
Hey I live in New Zealand andI recently bought a St165 and am trying to find out some information about LSDs. Are there front, centre,rear Lsds available for my car? Do St185s or St205s have Lsds available and do they bolt in?
Swaybars need to be upgraded but no one seems to stock them anymore. Any tips on sizes to make the beast turn in a bit better. Front? Rear?
I have had the car about a month, first weekend went into a Grass khana, That week bought and installed a full set of Tein adjustables. (Supposed to fit a St185 but with a little bit of thinking and top hat spacers, no problems). That weekend went and did a track day and pretty promptly ran out of brakes! So this week upgraded the pads to mintex 1166s much better now.
Ultimately would like to put a full St205 driveline under it. Any tips and suggestions would be appreciated. Most bang for buck etc. Avoid this and that. As Nz is a bit of a dumping ground for JDM cars a lot of good stuff does turn up here so compatibility hints are good as well.
Oh and since I live in NZ it's no use recommending so and so's shop but if you can recommend a (Hopefully global),brand then I can go hunting!
Thanks
bmt
Re: St 165 LSD
Postby Gary ST165 » Sat Mar 05, 2011 5:44 pm
# TRD front LSD (for ST185) is discontinued: http://www.greenline.jp/catalogue/fulli ... %20(3S-GTE :(
# stock centre diff is LSD by means of viscous coupling:
Image Image
# Rear TorSen LSD can be retro fitted from a ST185 RC / Group A Rallye / Carlos Sainz and was optional on some other ST185
Image Image
Rear TorSen LSD can be retro fitted from a ST205
Image Image
Rear plate / clutch type LSD is also manufactured by Cusco Image
& TRD Image
http://www.my-acoustic.com/Car/rear_axl ... at_LSD.htm
http://www.gtfours.co.uk/pics/trans/rea ... r_diff.htm
ST165 turbo 4WD
Gary ST165
Re: St 165 LSD
Postby bmt » Sat Mar 05, 2011 8:27 pm
Thanks for that. My car has the switchable centre diff. Locked or unlocked. I haven't seen anything about them other than they were only on the early JDM St165. Is it only good for low traction situations such as snow, gravel etc? At what speed can it be activated? Is it only when stopped or can it be operated whilst moving? Usually on four wheel drive vehicles there are multiple warning labels if it's a problem. Nothing on my car.
bmt
Re: St 165 LSD
Postby Gary ST165 » Sun Mar 06, 2011 9:06 pm
sorry i don't know much about the early JDM st165 centre diff lock...
http://www.alltrac.net/phpBB2/viewtopic ... 43&t=20104
ST165 turbo 4WD
Gary ST165
Return to GT Four Chat
