No boost?
No boost?
Postby skywind912 » Mon Apr 04, 2011 12:07 am
Not getting much boost maybe 3-4 psi at most...not sure what's wrong with it... any thoughts?
*edit* found some solutions on troubleshoot page
thanks!
91 Red Alltrac - SOLD
92 Black Alltrac
skywind912
Re: No boost?
Postby jonnyboygt4 » Mon Apr 04, 2011 11:01 am
do tell....boost leak?
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Re: No boost?
Postby skywind912 » Mon Apr 04, 2011 2:46 pm
Haven't checked for boost leak yet although on the troubleshoot page says "Hesitation under boost" that seems to be whats going on...the car runs fine just low boost when accelerating...here's what it says
Hesitation under boost - If you have noticed that your car works fine when not in boost but then stutters or hesitates when under hard acceleration (or boosting), it may be fuel related.  The most common problem is the fuel filter.  In a lot of cases the fuel filter has never been changed, and is dirty/clogged.  This is a relatively cheap replacement and should be suspected first.  If that doesn't fix the problem, the next thing to try is a general tune up.  Finally, if you are still having problems look at the fuel pump.  Especially for the ST165, you must realize that the fuel pump is over 12 years old and could be performing poorly.  Some tests performed on old used pumps showed they were only operating at about 15% flow versus new (extreme case).
So this is what I'm going to check first :)
92 Black Alltrac
skywind912
Re: No boost?
Postby jonnyboygt4 » Tue Apr 05, 2011 11:22 am
ok sounds about right...i had that issue last summer....then i did what is described, fuel filter (pain in the a$$), plugs , wires, cap/rotor...I also had a issue with rough starting which turned out to be the cold start injector...
goodluck!~
91 JDM ST185
jonnyboygt4
Return to GT Four Chat
