Need Stock "Under the Seat Amp" for door speakers
Postby Angrysquirel » Sun May 15, 2011 2:33 am
Hi All,
I just got finished replacing the stock 8" door subs with 6" Kickers (a lot of modification) due to the surrounds on the original speakers being totally degraded. To my amazement, after installing them, they don't freakin work lol.
I have soldered and ensured good connection to the new speakers - pulled out the aftermarket head unit (Eclipse CD3000) and checked all the wiring (looks good).
So after Googling for wiring diagrams and such, I find that the door speakers are actually powered by a separate amp (correct me if I'm wrong) on the "Super Live Sound System" 10 speaker system.
I have a harness with a bunch of male connectors under my seat, just no amp.
Would any of you have a stock amp for the door speakers lying around that you would sell? I cant take the speakers back that I installed due to the modifications :P
This is a JDM 93' GT Four.
"As a matter of deductive logic, Norman... we die down here"
Angrysquirel
Re: Need Stock "Under the Seat Amp" for door speakers
Postby Boo_Guy » Sun May 15, 2011 3:31 am
Ebay has them from time to time, only one listed at the moment though.
http://cgi.ebay.com/Toyota-Celica-GT4A- ... 19c21b6fef
Boo_Guy
Postby krogers128 » Sun May 15, 2011 4:06 am
jw but why wouldn't you just run an aftermarket amp like Alpine? mine fit right under the seat in my last three cars lol. and they provide awesome power/tuning ability.
1989 Toyota Celica GT: SOLD
1988 Celica All-trac JDM st205 swap: (project)
krogers128
Postby Angrysquirel » Sun May 15, 2011 2:52 pm
Well, it would seem that there are really proprietary connections under the seat there - I suppose I could hack and slash them together. There's nothing like an OEM fit tho :)
Ill check out that ebay one now - thanks for that!
Angrysquirel
Postby YerRandO » Sun May 15, 2011 4:46 pm
Simply adding the stock amp wont fix this, you loose its function when an aftermarket head unit is used. Search around you will find quite a number of threads on this. I used an aftermarket amp and mounted it in the stock location to power my kickers.
-James
YerRandO
Postby underscore » Sun May 15, 2011 4:53 pm
There are specific wiring harnesses that will work for keeping the system 10 amp working, the standard one that a shop will give you won't work, as for some reason the Celica isn't listed as a vehicle that requires this harness (I guess because it wasn't a standard piece?).
there's a thread on here somewhere on which harness you need, there's tonnes on eBay
Postby Angrysquirel » Sun May 15, 2011 10:19 pm
OK, thanks for that - I think I will purchase a small amp for the door speakers.
I will need to take it to an audio shop to have it re-wired - I did A LOT of searching through the forums and I cant find a definitive "cut here, splice here" for the wiring harness for the door woofers.
I appreciate the help guys! If you know of any diagrams, please reply, if not, I'll post the resolution soon.
Angrysquirel
Postby jonnyboygt4 » Mon May 16, 2011 12:00 am
i simply ran two crossovers instead of the amp under the seat...got the a audio shop to do it for me...but im running a sub in the back....pounds like a SOB...
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Postby Angrysquirel » Mon May 16, 2011 1:38 pm
jonnyboygt4 wrote:i simply ran two crossovers instead of the amp under the seat...got the a audio shop to do it for me...but im running a sub in the back....pounds like a SOB...
Ah, that sounds good - I already have an MTX road thunder (500WATT) connected to a 12" sub in the back - maybe I will do the same.
Ill keep you posted, get the shop to do a writeup of what they did, then post it here.
Angrysquirel
Postby Angrysquirel » Mon May 16, 2011 11:32 pm
I have decided that I will just run another smaller - ish amp to power the door 6's.
I have a few unused pre-outs on my deck - so thats that. Ill do a write up with pics when i get the time and $$
Angrysquirel
Postby underscore » Tue May 17, 2011 4:57 am
I take it you want to tap into the existing wires going from the stock amp to the door woofers? you can just run new wires to/from the amp for all this but if you prefer to just tap into the existing I can take a look at my setup tomorrow as someone did tap into the existing wiring in mine for a new amp.
Postby gtfour93 » Fri May 20, 2011 9:46 pm
I used a Metra 70-8112 Toyota Amp Integration Harness, when I replaced the stock head unit with an Alpine unit, along with a Pioneer DSP, and still have the stock amp under the passenger side seat. I also replaced the front door mid-bass subs with Kicker RMB8's.
http://images.sonicelectronix.com/image ... 708112.jpg
http://94supraturbos.synthasite.com/res ... 0-8112.jpg
http://www.crutchfield.com/S-ghkaTuH1bl ... -RMB8.html
TOYOTA TEAM EUROPE
gtfour93
Postby Angrysquirel » Tue May 24, 2011 2:34 pm
Yah - I will just keep it simple and run some wires from my existing amp to the door speakers - thanks for the input guys. This makes the most sense, and it should be the most cost effective.
Angrysquirel
Return to GT Four Chat
