1991 GT4RC Bucking and hesitating
Postby 91GT4RCboy » Sat May 21, 2011 2:03 pm
Hey guys, My RC recently started to buck and hesitate horribly while driving, at just around 3000RPM it begins to buck so horribly that I feel like my neck is going to snap. It seems to do this more often then not when its raining or particularly cold out in the mornings. Checked for codes and only found a 54 so I topped up my intercooler and am now back to square one. Any Ideas? Thanks.
Re: 1991 GT4RC Bucking and hesitating
Postby alltracst185 » Sat May 21, 2011 2:08 pm
Check your plugs, wires and cap and rotor first.
Postby jonnyboygt4 » Sat May 21, 2011 2:10 pm
i too have a similar problem...since i installed my fmic...seems to be surging when i accelerate hard...does this make sense?
91 JDM ST185
"just a little 4-banger"
Postby Corey » Sat May 21, 2011 3:40 pm
If ignition checks don't show anything, try checking the AFM. That was my problem.
Images: 50
Postby underscore » Sat May 21, 2011 11:21 pm
Check/replace your spark plug/wires, cap, rotor and fuel filter. Also check the AFM.
Return to GT Four Chat
