ST 165 fuel cut out
ST 165 fuel cut out
Postby JohnNK » Thu Sep 01, 2011 6:18 am
My 88 ST-165 is cutting fuel at 3500 RPM. The factory boost gauge is not registering anything. Is the turbo gone or should I check fuel line issues?
JohnNK
Re: ST 165 fuel cut out
Postby Mitsuslider » Thu Sep 01, 2011 12:35 pm
hook up a boost gauge and see what your getting, you could actually be over boosting on stock settings. find out if thats it then you can trick your boost sensor to stop fuel cut for less than $1.
Mitsuslider: "I broke your candy!"
Mitsuslider
Postby JohnNK » Thu Sep 01, 2011 1:59 pm
Thanks. The previous owner installed a manual boost control. I which check to see if it is over boosting.
JohnNK
Postby 88gt4DE » Thu Sep 01, 2011 7:06 pm
yup , or it blew a vac hose off it somewhere
Postby Mitsuslider » Thu Sep 01, 2011 7:33 pm
also boost controllers and the boost vsv (vacuum solenoid valve) do not play well togther, so if the vsv is still hooked up to the wastegate remove the line and cap the ends
Mitsuslider
Return to GT Four Chat
