3sgte awd questions
3sgte awd questions
Postby bigbacon » Fri Sep 23, 2011 1:37 am
I have a bunch of question about this engine/trans combo. I am looking at possible ideas for a swap into an AW11 and I keep seeing these combos for a lot less than the later 3s's from SW20 and such.
1. can you mate any other 5 speeds with this engine?
2. I assume since it is AWD it has front axle connections and then the rear drive shaft for the rear, if so, can one disable the rear postion while leaving the rest intact and usable?
3. length of the front axles and the spline counts.
Thanks, I tried my best to find info about this particular combo without alot of luck and i thought it would be best to ask the experts in the celica realm.
bigbacon
Return to GT Four Chat
