Will an st205 Water Intercooler fit in an st185 (Wide Body)?
Postby sbsolarski » Tue Oct 04, 2011 3:38 am
Hi,
I'm currently eyeing an st205 water intercooler (+pump +radiator) and would like to replace the standard air-to-air topmount that I currently have. Is there a lot of rework involved? I'm assuming it would be roughly identical to the st185 RC water intercooler.
The only issue I can come up with is maybe my bonnet (gt4 bonnet with scoop) may clash with it.
sbsolarski
Re: Will an st205 Water Intercooler fit in an st185 (Wide Body)?
Postby aus jd 2703 » Tue Oct 04, 2011 6:46 am
It can be done I'm running a full 205 intercoolEr including the front heat exchanger. U need to make custom coolant lines and drill and tap a pump mount but u can do it. Only catch with mine is the front heat exchanger mount is far from ideal it's low and doesn't get much airflow but it came with the front cut so it was cheaper than a new core.
The topheat exchanger clears the hood u maybe have to reomove the runner that's all. And the gen 3 head is different so u need to mount the top mount creatively but many have done that in the past
aus jd 2703
Postby sbsolarski » Tue Oct 04, 2011 10:38 pm
Thanks aus jd, I will take into account what you have said and think hard about making the decision to purchase it.
sbsolarski
Postby saved_1992 » Wed Oct 05, 2011 2:00 pm
this will give you an idea what needs to be done, this is on a 165 but fitting will be mostly the same
viewtopic.php?f=49&t=2136
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Return to GT Four Chat
