is it bad to run the car without the front cross member?
Postby alltracst185 » Sat Oct 22, 2011 2:19 pm
I have to moddify my front cross member or fabricate a new one because it's hitting my 3" exhaust. Is it bad to just not use it? Does anyone know if the Cusco front brace replaces it?
alltracst185
Re: is it bad to run the car without the front cross member?
Postby concealer404 » Sat Oct 22, 2011 8:35 pm
Like... the crossmember your control arms attach to?
Cars and stuff.
concealer404
Postby alltracst185 » Sat Oct 22, 2011 10:31 pm
concealer404 wrote:Like... the crossmember your control arms attach to?
Yes
alltracst185
Postby Flying Bajan » Sun Oct 23, 2011 1:31 am
:shock: :shock: :shock: :shock: :rofl: :rofl: :rofl:
Unless you are a miracle worker of some description with massive aptitude, good luck with getting the car to drive at all if you remove the cross member bro.
Flying Bajan
Postby CMS-GT4 » Sun Oct 23, 2011 1:46 am
Why don't you use the spacer washer method.
Postby underscore » Sun Oct 23, 2011 5:33 am
I would modify the exhaust, myself and my friend have custom 3" exhausts and have no issues.
Postby alltracst185 » Sun Oct 23, 2011 6:20 am
CMS-GT4 wrote:Why don't you use the spacer washer method.
Ya I thought about that, I'll most likely go that route.
alltracst185
Postby concealer404 » Sun Oct 23, 2011 1:53 pm
Yes
Well... that should answer your question, then? :D :P
Cars and stuff.
concealer404
Return to GT Four Chat
